Question about Canon imageRUNNER 5570 Copier
Canon ir 5570, we replaced the upper gear fuser on the operators side now i get an error code, e000840-0001. I have tried clearing the error code but the error still remains. Please help.
  • 821 Answers
Hello,to be honest the fixing assembly needs to be rebuilt. the sutter inside the fixing assemble has becomes warped or has locked up and the gears on it could be worn or broken.. unfortunately that is the only solution for the problem.
wish you good luck,
take care.
Posted on Aug 02, 2010
  • parksja767 Aug 02, 2010
    we trying ourselves. what is a sutter and where is it located in the machine.
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
Error code E000840-0001incanon ir 6055
My machine canon ir6055 display error E000840-0001 and E00060-0001 i am all so cheek the machine fuser unit last time automatic open the lock fuser i am set the fuser agin problem
and E000013-0001
Jan 17, 2013 | Canon imageRUNNER 5570 Copier
My canon C3170i shows error E000001-0010
Product : imageRUNNER 5070 / 5570 / 6570 Title : Fuser noise and intermittent E001 code Error
The upper fuser roller section makes a noise and intermittently error code E001 occurs Workaround : In this case, the UFR Shutter inside the upper fuser roller was installed reversed (180 degrees out of postion). Installing the UFR Shutter in the proper orientation corrected the problem. Note: the UFR shutter installed in the reversed position will cause a noise and block the Main Thermistor when the shutter should block the Sub Thermistor. In turn, the shutter will block the Sub Thermistor when the shutter should block the Main thermistor. This will cause improper temperature for the Upper Fuser roller and cause the error code. suggested to go in service mode and reset the error, and see if it will solve the problem. If the problem presist, a code will appear and that will be the one we should work on. So we did clear the error, and the machine is functioning.
Entering service mode: press Additional Function > press 2 & 8 at the same time > press Additional Function again Clearing the Error: press Copier > press Functions > press clear > press Err > press Ok. Restarting the Machine:Power off then On.
Oct 12, 2011 | Canon Office Equipment & Supplies
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
I have copier ir 400s sir i am getting error when i started the machine the error is E014 thank you
This is an indication that the fuser ( hot rollers on left side of copier ) are not turning. This could be caused by several things. Try turning the green knob behind front door. Does it move smoothly? If it doesn't then remove the left side fuser door and remove the fuser assembly. The bearings for the upper and lower rollers could be bad. If the fuser moves easily, then it could be a white gear that is located on the upper right of the fuser assembly. This is the drive gear for the fuser. The gear tends to wear out over time and has to be replaced. This should get you in the right direction to solve the problem.
Mar 28, 2011 | Canon imageRUNNER 400S Copier
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
HAVE CANON IR C6800 WITH THE FOLLOWING ERROR CODE... E000001-00ff
moz-screenshot.jpgmoz-screenshot-1.jpgIt is a Fuser error code .
Could be a poor connection with the draw connector on fixing feeder unit.
Try shimming all three connectors on the fuser draw side can resolve the issue. Another thing to check is the upper fuser roller for flat spots this can also cause fuser error codes
May 07, 2009 | Canon imageRUNNER C6800 Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
IR 5570 Error code
Subject:E840 Indicated in response to damage on the Fixing Roller Trust StopDetails:<Problem>Damage to the Fixing Roller Thrust Stop leads to the indication of error code E840. At times, it can also indicatecode E001/E004.<Cause>The strength of the Fixing Roller Thrust Stop [1] is not adequate and over time, it tends to show damage, failingto prevent the Fixing Roller from moving to and from. Or, the damaged stop can fall to the Shutter DriveAssembly to cause the shutter to malfunction, also resulting in an error.
<Factory Measure>Modify the method used to shape the fixing roller thrust stop to increase its durability.
Servicing Work:If any of the foregoing symptoms is noted, or in the course of a service visit, replace the existing Fixing RollerThrust Stop with its new type.
Sep 24, 2008 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5570 Copier Logo
199 people viewed this question
old marine
old marine
