Question about Car Audio & Video
2001 chevy prizm radio will not turn on. It will display the time briefly then the time also goes off
Did you find out the problem as my radio just started doing the same thing?
Posted on Nov 23, 2010
Radio turns on but no sound chevy 2001 Tahoe factory radio
Time for a new stereo,when the sound goes.that's it.also hard to find anyone that works on car stereo's.
Jun 16, 2015 | 2001 Chevrolet Tahoe
Whining noise that stops when you turn the wheel on a 01 chevy prizm
Add some power steering fluid problem solved if not replace power steering pump problem solved.
Apr 18, 2014 | 2001 Chevrolet Prizm
My 2001 chevy prizm quit working. I pulled up to a stop sign and it died. I've replaced the fuel pump and the relays and still no joy
theres a way to test the fuel pump before you replaced it is your vehicle getting fuel is it getting fuel from plugs is the timeing belt broke
Dec 28, 2010 | 2001 Chevrolet Prizm
2001 Impala TPMS reset, radio and headlight options DONT WORK
CHEVY IMPALA &
MONTE CARLO
On a Chevy Impala or Monte Carlo with indirect TPMS, a totally different reset procedure is required. You can use the light switch or radio to reset the system. With the light switch procedure, turn the ignition on (engine off), the turn the light switch from OFF to parking lamps three times within five seconds. With the radio technique, turn the ignition on (engine off). With the radio off, hold the DISP button until “SETTINGS” is displayed. Use the SEEK button to scroll down the menu until you see “TIRE MON.” Press the PREV or NEXT buttons until “RESET” is displayed. Then press the DISP button again. You should hear a chime and see “DONE” to indicate the TPMS system has been successfully reset. Use the SEEK button to scroll through the menu until “DONE” is shown, then press DISP once more to exit from the learn mode.
Dec 24, 2009 | 2001 Chevrolet Impala
2001 Chevy Prizm, only 35,000 miles - radiator hoses; drive belt
At 35,000 miles, no, I wouldn't worry about the hoses, or the belt. I have a 150,000 miles on my vehicle, and never changed either one.
Oct 20, 2009 | 1999 Chevrolet Prizm
Where is the fuses located in a 2001 chevy prizm? radio stopped working trying to find fuses
open the hood.on the left side there is a fuse box and also in the lower left of the dash underneath there is a cover and fuses inside.
your car is built by united auto works in fresno calif. and is the same as a 2001 toyota corolla if you need parts.just the body panels lights etc are different.
Sep 14, 2009 | Scosche Industries Scosche Gm05b Wiring...
My vauxhall stereo is stuck on safe mode how do i unblock it i have lost the code
1. turn ignition on (dash warning lights on)
2. If radio turned on, turn it off.
3. Press AS button in, and hold it in while turning radio on.
4. Wait approx 10 seconds (do not release AS button).
5. Radio should beep, and display should now read 10 - - - - (assuming no tries have been made in the past with the wrong code)
6. use pre-set button "1" to scroll the first digit in the display to the number you want (it goes 0,1,2,3,4,5,6,7,8,9 then back to 0)
7. Use pre-set "2" for second digit, etc.
8. Once display reads 10 followed by the four digit security code press and hold AS button for about 10 seconds, until the radio beeps.
9. If correct code entered display will now read "code" briefly, followed by"memory-U" briefly, then radio will reprogram it self.
10. If radio goes back to "safe" the code number is incorrect, or you mis-keyed it.
Note: entering the code incorrectly 10 times will render the radio useless.
After the first 3 tries you need to leave the radio on and the ignition on for increasingly long periods of time before it will let you try again. 7 safe need you to wait at least 30 mins, and more like 1 hour.
WARNING - you only have a max of 10 attempts to get it right, but if still no luck after the 8th attempt, STOP and contact a Vaux dealer.
Sep 06, 2009 | Car Audio & Video
2001 Chevy Tahoe radio problem
Your Display will Eventually Stop alltogether. Happened on my 2000 Blazer and had to replace with Aftermarket Stereo. Dealer wanted WAY too much for new unit.
Jan 04, 2009 | 2001 Chevrolet Tahoe
2001 Chevy Prizm Horn repair help
buy a new horn and replace it.
Jul 16, 2008 | 2001 Chevrolet Prizm
Car Audio & Video Logo
107 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
