Question about Dishwashers
Dishes are still dirty. I have used every kind of dishwasher aide, half loaded it and dishes are still dirty, I let the water run until very hot before starting the washer. The washer says you don't have to rinse but I do and they still come out dirty. Also black nasty stuff comes up from my garbage disposer.
Suggest the problem may be a plumbing issue - likely substantially blocked drain system, so the dirty wash water cannot properly pump out but rather remains in the dishwasher.
Suggest getting a plumber in to "snake" out your kitchen drain system. You will probably notice your sink drains will suddenly work much better too...
Posted on Aug 02, 2010
The dishes just don't get clean. I know this isn't much to go on, but that's it.
Is the water hot? (make sure hot water is available to the machine at the start of the cycle by running the sink faucet until it is hot) Are you using the internal heater? (check the control panel for this feature) Are you using the entire cycle? (time) We are not talking about baked on food here are we? Dirty dishes that have dried?
Dishwashers cant remove baked on food no matter what the advertisement said. If the food is dried on, there is a better chance but ... dishwashers work best with freshly dirty dishes. If the food is dried, at least let them soak in the dishpan for a few minutes before you put them in.
How are you arranging the dishes, can the water reach all surfaces? (Think tempest in a teapot).
Have you tried other detergents? My preference is liquid though others may prefer granulated or tablet. I also like to use a product called Rinse-Aid.
If you have considered all these ideas and the dishes are still dirty ... there may be a mechanical fault with the machine. Is it making the proper noises?, Filling and emptying properly? (listen to it)
I hope you find these suggestions helpful ... Thanks for your visit today.
Jan 27, 2011 | Amana 24 in. ADB2500AW Built-in Dishwasher
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Takes two and a half hours to run a load of dishes
They probably aren't running the hot water at the sink before starting the dishwasher. You know how it takes time to get hot water at the tap when you turn it on? well the new dishwashers use such little water, that they will fill with cold/warm water, and try to heat it up to 170+ degrees before continuing the cycle
Apr 04, 2010 | Dishwashers
Does the two drawer use liquid or powder soap? Kitchen Aid Dishwasher is not washing things clean, there is a coating of dirty food particles on the dishes. Help!
About the soap: You can use both. I prefer tablets.
About the particles: Before putting the dishes in, remove the food with a brush ($2.00) in the sink and run the hot water from the faucet for a 1-2 min until it gets really hot.
Sep 30, 2009 | KitchenAid Dishwashers
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Motor and pump replaced still not getting dishes clean
Place a cup of vinegar in top rack corner (upright) and run an empty cycle to clean any build up.
Stop using any rinse-aid (jet-dry etc.), if the detergent you're using already has it included. Too much rinse-aid can create a white film on your dishes. A good way to check for rinse-aid build up is to run your fingers on the inside of the cabinet and check for a white powdery residue on your fingers. You can also run the dishwasher for a couple of minutes and check for excess suds in the water when you open it. Excess suds would indicate a rinse-aid build up.
Run the hot water at the tap before starting the cycle and make sure it's at the recommended temperature (120-140°F).
Mar 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Film on dishes
the problem is hard water. this is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Oct 28, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwashers Logo
156 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
