Question about Craftsman Garden
Sears Tractor 917.28974 blows fuses
Sears Tractor 917.28974 keeps blowing fuses. Checked starter, switch is fine but every time I put a new fuse in and turn tractor on, the fuse blows. Cannot locate a wiring diagram.
  • 53 Answers
SOURCE: Fuse keeps blowing
check thwe stater up under the flywheel, sometimes they get dirt and grass up there and mess with the copper coil. also i had one one time that the stator had a bad wire one time and was blowing fuses also. all i did waS cut that part of the wire out and fix problem. good luck
Posted on Jun 21, 2009
mowerman1857
  • 389 Answers
SOURCE: Sears lawn tractor tubeless tire replacement
Most local tire shops have or can get tires and tubes of the size you want/need and would install them as well. Without the proper tools, they can be a "bear" to change but if you insist upon doing it yourself, go to a GOOD lawnmower repair shop and have them order the sizes for you. It has been my experience though, the tire shops are cheaper
Posted on Sep 14, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
jdlipscomb41
  • 157 Answers
SOURCE: need wiring diagram for ford 4000 tractor 1967
check ebay
Posted on Oct 26, 2009
ftw1952
  • 10319 Answers
SOURCE: tractor keeps blowing a fuse
Check for a wire that has a bare spot on it rubbing the body of this mower. The vibration the engine makes shakes the wiring so it must have a bare spot somewhere under the seat or towards the engine
Posted on May 30, 2010
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Mar 06, 2015 | John Deere Garden
I have a 1999 dodge avenger that keeps blowing the 30amp engine fuse under the hood it only blows the fuse when I crank the ignition checked all the words not sure where to look anymore any suggestion's
If it just keeps blowing it could either be a bad ground somewhere or theres to much power getting pushed to it for some reason when u start it, blowing the fuse
Jan 03, 2015 | Cars & Trucks
Ok well I put in a brand new starter because my crank sensor keeps blowing and thinking I fixed the problem long behold I keep blowing my crank fuse when I try starting the truck I don't know wear to start
No, year make or model. But if you blow the crank fuse, it is between the starter and the ignition switch. Could be the switch, but most likely the wire. At the relay there are four pins. 30 is B+ all the time, 87 is to the starter. 85 and 86 can be switched. But one is B+ with the key in start position, the other goes to the ECM, this would be ground.. Since you're blowing the fuse, you need to find the short to ground. this would be the 85 and 86 wires.
Oct 26, 2014 | Cars & Trucks
95 ford mustang starter fuse keeps blowing. what should i do?
have you checked that the starter itself has not been grounded out (short in the wiring?)
The chances are this is what is causing your problem, start at the starter motor & follow the wires, check every single one, if you have a bare section that comes in contact with the body or anything else metal it will ground out that wire & cause the fuse to blow every single time even if you were to double the fuse resistance I.E. if the fuse is a 20 & you put in a 40 it will still blow - that last part is ill advice - never put a higher amperage fuse in a socket that was intended for a lower amperage fuse - it could cause a fire & serious injury, check all your wiring from the starter you have a short in the system somewhere it's just a pain in the a
4rse locating it
Sep 21, 2012 | 1995 Ford Mustang
Starter Fuse Keeps Blowing When I Try To Start My 2001 Camry
The starter has gone to ground. This is either a coincidence of age or the repair shop left something disconnected that has slapped around and grounded the starter or some of their other work has shifted around and done it. It could just be a coincidence. If it went to ground internally, it will need replacing. If something shifted and grounded it out, putting that something where it belongs and THEN replacing a fuse should fix it. Most shops reuse your starter on their new engine.
Apr 16, 2017 | Toyota Camry Cars & Trucks
I keep blowing fuses when I try to start my 883. After tracing wires I can't find a dead short anywhere. All the lights and horn work fine. Only when I hit the start switch does it POP. I have checked...
Do not put a bigger fuse in the slot. If you do, you'll just burn up your wiring harness. A fuse is there to protect the wires. The fuse does this by blowing if the maximum current capacity of the WIRE it's protecting is exceeded. If it's blowing the fuse ONLY when you press the start button, it's in that circuit somewhere. I'd pull the starter relay and try it again. The relay is on the backside of the oil tank. You'll have to take the seat off to get to it. If it blows a fuse then, the problem has to be in the wire that comes from the start button going to the relay. If it does not blow the fuse, buy an new relay and install that. If it starts blowing the fuse again, you'll have to look at the schematic and find out where the wires go and trace them out. If you aren't getting any voltage at the blue wire, pull the relay and do a continuity check from the end of the wire where it plugs onto the starter and the frame. Pull the wire off the terminal on the starter and test it. If you have continuity, you have a short somewhere in that wire. Contact me directly at wd4ity@bellsouth.net and I'll send you a schematic. Remind me of what you need.
Good Look
Steve
Jun 27, 2011 | 1993 Harley Davidson XLH Sportster 883
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
30 amp fuse blows when trying to start engine
I always start by unplugging lights, kill wire to coil electric clutch if it has one ,sometime its the fuel shut off solenoid on the bottom of carb if it has one.
You can keep trying until you find the thing that does not blow a fuse or use an ohm meter to read from pos cable to ground of tractor unhook ground wire to battery you will read short to ground thru coil kill wire,starter solenoid small wire on spade,fuel shut off
solenoid ,electric clutch ,rectifier (charging system )and large wire to starter thats why I unplug them .
I have seen more shorts from lights , fuel shut off solenoid , charging system. not ing coil not safety switches not even bad starters.
good luck
Jan 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
140 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
