Question about Brother HL-5240 Laser Printer
Toner lite will not go out or print
Toner lite stays on after replacing toner cartridge & will not print
  • salma A May 20, 2008
    1. switched printer off and on.
    2. swaped cartridges with printer that works to check the toner of the printer that doesn't.
    Problem Solver:
  • 12 Answers
A couple of suggestions
1) Open door and remove drum and toner. Hold Go button down until all lights are on. Put drum and toner back in and shut door.
Another is.
1. Switch off printer
2. Switch on printer
3. Open front door
4. Remove toner/drum unit
5. With the door still open hold down the go button for 1 second
6. Put the toner/drum unit back in
7. With the door still open hold down the go button for 1 second
8. Close the door and press go to test
Posted on Apr 25, 2008
Data and alarm lights stay on,won't print
The Toner cartridge is empty, You can possibly take out the toner and tilt it fron side to side and maybe get a few more prints, but most likely you will need to replace the toner.
Mar 06, 2011 | Brother HL 1440 Laser Printer
Gear train on toner cartridge locked up and caused a red light on printer to come on. Replaced with a new toner cartridge but red light stays on and it will not print.
may be it will be the problem that some sensor of printer like exit sensor or sensor which r displayed under the toner cartridge will be in busy condition
Nov 22, 2010 | Samsung ML2251N Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Lite toner marks on paper
The imaging drum is included in the toner cartridge on this one, so you could need a new toner cartridge. If that doesn't fix it, then you are looking at either the transfer roller or the fuser needs replaced. Workgroup printers usually require a maintenance kit after 300,000 pages printed, fyi. that kit includes feed rollers, a fuser, and a transfer roller. Not sure what the page count is, but that could help you figure it out.
Nov 03, 2009 | Lexmark T644 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Toner
You could try two ways.
1) reinstall the software.
2) push "start" buttom for 1 min
Sep 16, 2008 | Brother HL-2040 Laser Printer
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Toner light stays on!!!
Open the toner door, then press and hold the 'Go' button till all the lights are lite, this will reset your drum counter.....
Nov 19, 2007 | Brother HL-2040 Laser Printer
Brother HL-5240 Laser Printer Logo
243 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
