Question about APW Wyott Kitchen Appliances - Others
Machine won't rotate at top so popcorn burns on bottom. How to fix? Thank you.
  • 2,272 Answers
This problem can be related to few possibilities:-- there is a motor which spins the top. either the motor is getting blocked or its weak or faulty,Or the motor connections have got cut in between or short in between.It has to be checked.But if motor checked ok then its the controls problem. motor located in the vented part of top cabinet. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 02, 2010
Why won't the kettle heat up to pop
The heating element needs to be checked to see if it has power and if it has burned out. To do this, you need a meter that checks voltage and resistance. To test it, locate the connections to the heating element and with the machine unplugged test the heating coil with the meter set to measure resistance. It should not be infinite. IF it is then the coil is burned out.
Jun 14, 2014 | Cretors Goldrush Popcorn Maker
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
How to fix this problem?
See if the gear at the top of the kettle rod is "jumping" and not allowing tehe stirrer to rotate properly. In my machine, this was caused by a broken black guide at the atop the two gears. The guide is screwed into place. It allows the gear to slide in and out as you rotate the kettle, but it also has to prevent the rod from moving back and forth or the gears will slip
Sep 13, 2012 | Nostalgia Electrics Helman Group CCP-509...
The popcorn gets stuck in the kettle until it burns
I have a Popcorn machine from Nostalgia too that had this problem. I cleaned it out and everything but it still had the problem of the it getting stuck. After days of analizing, I found the solution. after a while the ceiling of the popcorn machine starts to fall in, lowering the handles of where the kettle goes. making the knob that turns being lower that the one that makes it turn, causing it to get stuck, all I did is add so leverage so the kettle is once again at the same level or higher. Making it turn with greater force and not getting stuck. In other words make sure the turning mechanism is leveled and not one lower than the other. preferably the kettle part being higher.
Jan 09, 2011 | Nostalgia Electrics Helman Group CCP-509...
The popcorn popper heats the oil and the warmer light also works, but the turning device has stopped working so the popcorn burns. Can this be repaired?
hello,
the citation popcorn can be repaired the problem is from wiring disconnection
what you need to do to fix up the problem i to unscrew (open)the popcorn maker from the top with the bass tools then trace down the wire to the propeller (tuning device) to see if the disconnected wire then try to fix it back to it position but if there is no sign of disconnection then smell the wires if there is an born wire then the wire will need to be replace note this if any of these are not fine then you will have to replace the propeller i mean the turning device but
if you can not do this your self then you will have to take it to a technical shop around. you can get the turning device from an technical store / shop you
please take note of this, you must make sure that all source of power supply is put OFF from the machine.
than you.
Jun 12, 2010 | Gold Medal 2102E Deluxe Citation Popcorn...
OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Sep 21, 2009 | Microwave Ovens
Elite Cuisine EPM 400 popcorn machine
Maximatic Deluxe Popcorn Trolley Elite Cuisine EPM 400 popcorn machine burner is burnt out. where can i find a replacement pot?
Jul 23, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
Popcorn maker jams up - burns kernels
Please call Nostalgia electrics at 1-920-347-9122 so we can help you get the piece you need.
Nov 25, 2008 | Bond Helman Old-Fashioned Movie Time...
Kitchen Appliances - Others Logo
Top APW Wyott Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an APW Wyott Kitchen Appliances - Other Expert? Answer questions, earn points and help others
