Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Bissell Powersteamer will not eject cleaning solution what can I do to fix it?
  • 276 Answers
Try these suggestions to get your machine working properly:
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
If these suggestions do not resolve your issue contact BISSELL Consumer Services for further assistance.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Posted on Aug 03, 2010
4 Suggested Answers
SOURCE: Bissell Powersteamer 7901
I have a bissell proheat 9400 it is not dispensing the cleaner what can you do to fix it. Debra
Posted on Apr 06, 2008
Vac Belts
  • 701 Answers
SOURCE: Bissell powerSteamer Pro manual free download
You can get on here:
http://www.vacbelts.com/bissell-powersteamer-pro-belt-pack.htm
Posted on Feb 05, 2010
BissellCSR
  • 276 Answers
SOURCE: Bissell powersteamer
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Posted on Oct 13, 2010
Jul 09, 2010 | Bissell 8806 Powersteamer Upright Vacuum
How to maintain my machine i lost my manuel
You can get the manual here:
http://www.retrevo.com/s/Bissell-1697-W-Vacuums-review-manual/id/10039bh340/t/1-2/
Apr 30, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1698-p proheat powersteamer instruction manual
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Apr 10, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Powersteamer Proheat 1698 has rusty motor fan
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
476
Mar 27, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Can a bissell powersteamer work if the belt on the
heatman101
retr
Nov 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Mar 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
1,467 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
