How to connect the router to my computer and broadband?
    Master:
  • 441 Answers
That is simple. Please provide me the band and model of the router and the operating system of your computer,also the name of your Internet Provider.
Or
contact Supportrix @ 1-877-SUPTRIX (7878749) and give this promo code "supportcall" to the technician to gain 1 free support.
Or visit us @ www.supportrix.com
Posted on Apr 25, 2008
How to install a Wireless-N 3G MIMO Broadband Router
What are you trying to connect with ? A laptop? What kind? What OS are you using? If it's connected correctly and you can access the internet with a Ethernet Cable attached to the Netgear and the computer, it may be a computer wireless issue.
Jan 18, 2013 | NetGear MBRN3000 3G /4G Mobile Broadband...
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
My connection is very slow,it is smart broaband
hi there, you don't need a router for smart broadband or other wireless broadband, cause all wireless broadband is already routed, if you used a router the connection will slow down due to NAT and built firewall of your router. Option: If you want to share your internet connection to other computer, used a HUB switch this would be better. thanks
Apr 30, 2011 | Computers & Internet
My laptop is conecting but says limited or no connectivity but I have a strong wifi signal
Did a bit of research for you on this and came across a ten step set of instructions which should hopefully correct, or at least narrow down your problem:
Jan 04, 2011 | IBM ThinkPad X40 Notebook
SkyLine Wireless Broadband Gateway (PN8584-1) Router: I do not have the instruction book for this router...
Your main computer should plug directly into the router. Just remember, your other two computers, if they are NOT laptops, have to be WIFI ready (additional hardware). Laptops come with this hardware.
Nov 30, 2017 | Proxim SkyLine Wireless Broadband Gateway...
I want to secure my wireless broadband router..how can i secure it?
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Mar 03, 2010 | Linksys Wireless-G Broadband Router
DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
May 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Broadband
purchase and install a broadband router. connect both computers to the router. make sure to follow the particular routers setup instructions fully
Mar 22, 2009 | D-Link 4-Port Ethernet Broadband Router...
Installation
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and if your ISP is dsl configure the router settings by setting your isp username and password
Step 7: test the Internet connection.
May 07, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
David Payne
David Payne
