Question about NorStar M7324 Corded Phone
We seemed to have a power outage over the weekend. We have M7324 system with 6 rollover lines, only the first two work now, the other four are not working. I rebooted the system, no change. Can you help?
  • pete827 Aug 13, 2010
    You guys are about a week and a half too late.....please refund my money
  • 105 Answers
You must have an older system. There is a battery built into the control unit (not user replaceable) that stores the system programming in case of a power outage. When the battery is dead, your system will lose all programming and default to assigning the first 2 lines to all phones. The system will have to be completely reprogrammed.
Please Note: Now would be a good time to install a UPS/Battery Backup unit on the phone system. I recommend a large enough unit to keep the phones running for at minimum of 2 hours during a power outage. Install the UPS/BB first, and then reprogram the system (so it won't have to be reprogrammed twice). Good Luck!
Posted on Aug 13, 2010
  • Michael DeAngelo Aug 13, 2010
    Sorry I couldn't get to your problem sooner Pete - I'm new to this site. As far as I can tell, you should not have been charged for my solution, this was a free answer to the problem you posted on the FixYa website. I can tell you I am not getting a penny for my advice to you. If you need help in the future, feel free to contact me.
When I pick up my nortel norstar phone m7324 line 6 lights up can I change this to line 1?
In tech programming (Config) you need to got to the Line data and remove lines 2, 3, 4, 5 and 6 from the pool it is in, make it none.
Note if line 1 is in use then you cannot call out.
Note sure why you would want line 1 as your outbound, systems are to use the bottom lines out and work their way up and inbound starts at the top and works their way down.
If you dont know how to program or the password call your local vendor in for a 1 hour charge.
If there is some strange reason then state what the setup or issue is and we can see if there is a work around.
Nov 08, 2012 | Nortel Norstar M7324 Receptionist Phone,...
Norstar m7324 won't come off night ring
Is the button still programmed?
Do F871 in meantime....F#871 on older systems helps too or just F87.
Program button:
F*3
button
Feature
871
Jul 23, 2012 | NorStar M7324 Telephone
Hi, Can any body help us? We have a M7324 on a Norstar Compact with two line pools, Pool A is on Line 1,2,3 and Pool B on Line 4,5. We want to add another line on Pool B so I tried configuring Line 6 which...
On the cross connect do you have a CO connected to that line. That is most likely the cause of no dial tone. If you don not know how to check that call a phone system expert to connect and verify your system.
Feb 15, 2011 | NorStar M7324 Telephone
Power outage now you have to select a line manually instead of just picking up phone and it's taking awhile before it starts ringing
What usually happens after a power outage is the system defaults because the backup battery in the memory card is dead. That means 2 lines only on every phone, pulse dialing, and all phones ring. If your system looks like that, it's time to call the Nortel repair tech. He can replace the battery or software module with a new one and reprogram the system.
Carl
Aug 17, 2010 | NorStar M7324 Corded Phone
Norstar phone m7324 1. What is the difference between the name of the "line" and the name of the "set"? 2. Is there a way to reset the lines other than unplugging the phone system? Four lines are showing...
1. You can name the lines, for example (Line 1, Line 2) - or - (5551234, 5551235). You can also name the sets (phones), so when Joe calls Mary, Joe's phone will display "Calling Mary", and Mary's phone will display "Joe calling".
2. Press the line button for the line in use and the display will show which extension is using that line. There could be a stck button on a phone that is tying up the lines. When you figure out which extension is causing the problem, try unplugging it to see if that clears the problem (it should). Then get the trouoble phone repaired. Good Luck!
Mar 15, 2010 | NorStar M7324 Telephone
We just bought an m7324 system (on order, used) and wanted to know the wiring req'ts for the jacks - 6 conductor? 8? straight through or crossed?
The nortel system is a digital system which only requires 1 pair (pins 4 and 5) to power the telephone set. Only when a cap is used on a set is the second or third pairs used. The sets aren't polarity sensitive but, it never hurts to keep your wiring straight through.
Mar 11, 2010 | NorStar M7324 Phone
Power went off in our office over the weekend. Now my phone doesn't ring on all the incoming lines. Help!?
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Oct 27, 2009 | NorStar M7324 Telephone
Line in Use
It's possible that the last caller, never gave the system the "Disconnect" it needs from the phone company. Try rebooting the phone system. Just pull power on it, let it sit for 10 seconds, then reapply power.
Jul 14, 2009 | NorStar M7324 Telephone
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
Norstar 7324-two lines show in use, but wont hang up
Power cycle the system. You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop.
May 26, 2009 | NorStar M7324 Telephone
NorStar M7324 Corded Phone Logo
272 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
