Question about Microwave Ovens
Panasonic Microwave model NN-S263 that works but only with weak power level. Takes much longer to heat food than normal. Is this a fuse, or do I need a new magnetron?
    Brigadier General:
  • 3,513 Answers
Hi
The food is heated by the microwaves themselves and these microwaves are piped into the cooking chamber from the magnetron. The magnetron has electric charge sloshing back and forth in its tines. A small antenna uses that sloshing charge to emit microwave radiation. The water molecules in the food absorb this microwave radiation and turn its energy into heat.
However you'll need to check the voltage on your element terminals with a voltmeter,put the volt meter probes on both element terminals while its on and you should get 240 volts. If you do get 240 volts, that means your element is bad.If your line voltage is correct and it is slow to heat, then almost certainly your magnetron is failing.
If it's within the magnetron portion of the warranty but out of the original full warranty, then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 02, 2010
  • mdbowker Aug 02, 2010
    Thanks for the answer. Because this is an over the range microwave, I suspect I have to remove it to get at the elements. Also, I would have to find a friend with a voltage meter to check it out.
    I'm thinking that I should probably replace the whole microwave, although because it's such a behemoth it won't be cheap.
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
My Panasonic Model NN-S252WF is not heating properly, it takes about 2x as long as normal to heat something
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 15, 2010 | Panasonic NN-S252WF Microwave Oven
Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghdgh
May 13, 2010 | Panasonic NN-S963BF Microwave Oven
Won't Heat - Panasonic NN-S668BA
first off does your unit have the word inverter writen on it if it does it could be a failed magntron or the invertor pcb approx repair between £70-150, if it does not then it could be the capacitor or the diode or the hv fuse or the transformer this would be a repair under £90 sorry i cant be closer in price it would need someone to have the right testing tools
Oct 08, 2009 | Panasonic NN-S668BA/WA Microwave Oven
Where is the fuse located inside the Panasonic Micorwave Model NN-S263
On most microwaves the whole cover that wraps around it should come off by removing the screws on the back. The fuse more than likely will be a tan color and ceramic. It will be about 1 inch long and the diameter equal to that of a pencil. Once you get the cover off it should be noticeable. Just look around. Be sure to replace it with the exact same one. I would take it in to radio shack or a appliance repair store to make sure you get a match. Good luck!
Aug 29, 2009 | Panasonic Microwave Ovens
Microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Panasonic NN- S760BA heating problems
Chances are it has a bad magnetron. If you decide to have it serviced, I would definitely recommend that you contact a servicer who is authorized by Panasonic. You can find them here: http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001 Good luck.
Feb 20, 2007 | Panasonic NN-S762 Microwave Oven
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
