My 2002 toyota hi-ace van super grandia is overheating at noontime, what are possible causes?
  • 14036 Answers
SOURCE: help me find the regulator on a 1978 Toyota Hi ace
THAT YEAR TOYOTA USED A TIRRILL IC THE INTEGRATED CIRCUIT ITS THE INTERNAL REGULATOR MOUNTED ON THE INSIDE OF ALTERNATOR. AND THE TIRRILL EXTERNAL REGULATOR.ITS MOUNTED ON THE FIREWALL OR FENDER WELL.IF YOU DONT SEE ONE YOU PROBABLY GOT A INTERNAL REGULATOR.IF YOU HAVE EXTERNAL REGULATOR ONE WAY TO TRACE IT IS TRACE ALL WIRES LEADING TO ALTERNATOR.YOU WILL SEE WIRES LEADING TO A LITTLE SQUARE BOX WITH COVER.
Posted on Nov 13, 2009
  • 181 Answers
SOURCE: locate fuse box toyota lite ace van 1994
most 94 van fuse boxes are located behind center console I could not find ace van on alldata
Posted on Feb 11, 2010
  • 17386 Answers
SOURCE: Lost key for Toyota Hi Ace super custom 1992, how
notify a dealer will need vin number proof of ownership and id and a dealer should be able to cut u a key
Posted on Jun 02, 2010
noranda21
  • 1547 Answers
SOURCE: digital clockofmy toyota hi ace
what year is vehicle
Posted on Dec 03, 2010
SOURCE: which is the best way
Try to lift up the whole bucket seats from the drivers side towards the right. Use the back seatbelt to hang the bucket seats. The engine is right inside the front row seats. That is where you can remove the engine thru drop it down..
Posted on Jun 29, 2011
How to reset check engine light of 2015 toyota super grandia.
First you need to check the code which tells you what the fault with the engine is. It would be foolhardy to just cancel it. The code reader is also the piece of equipment to cancel it. Your local garage will normally tell you what is wrong with it for free in the hope they get the business.
Here is a list of all the things it is telling you that could be wrong.
http://www.obd-codes.com/trouble_codes/toyota
Jul 16, 2016 | Toyota Cars & Trucks
How do I replacing indicator relay on Toyota Liteace?
Hi Duncan ,follow this link to a toyota van forum , register and get the location with pictures
ToyotaVanPeople com
Jun 12, 2014 | 1988 Toyota Lite-Ace
Toyota hi ace power van 2.4 diesel alternator removal
i believe on this model the alternator is located on the bottom of the front of the engine.and comes out from the bottom 4 clearance. loosen belt tensioner first then loosen mounting bolts .dont forget to disconect battery first.
Mar 21, 2013 | Toyota Van Alternator / Generator Nippon...
What is the remedy if my hi ace is still overheating ! My piston ring is 0.75 then my liner and piston is 0.50?
Check water pump/coolant pump. If more than 100 thousand Km, the fins may have eroded enough to not move coolant through engine adequately.
Apr 11, 2012 | 1995 Toyota Hi-Ace
Toyota hiace super custom over heating during idle ingine
how to fixed my toyota hi ace super custom from over heating
Feb 03, 2012 | Cars & Trucks
Locate fuse box toyota lite ace van 1994
Feb 11, 2010 | 1994 Toyota Camry
Toyota estima 2.2 td 1992 van overheating
the impellors in the water pump are prone to corrosion,especially if no or incorrect radiator additives have been used .this will cause water to stay in motor & boil whilst the water in the radiator stays cold because it cannot circulate.try flushing radiator ,installing a new thermostat (which is more than likely not opening )& radiator cap,refil with correct additive,.if the car still over heats then you will need to replace the water pump.bugger!!
Dec 28, 2008 | 1992 Toyota Previa
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
