Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Home network router goes one way only
Home network router problem. computer ''A'' cannot ''see'' computer ''B''. But computer ''B'' can see computer ''A'' Both can access internet with no problems.Network is ethernet. Computers both XP with SP2. Router is actiontech. ISP is Verizon FIOS
  • 1 more comment
  • rafewrite Aug 02, 2010
    I've already posted two comments to the original expert and I'm willing to keep working with him but your program keeps asking me to accept or reject his solution. I'm new to this forum and don't know how to do this.
  • rafewrite Aug 03, 2010
    Yes, helpful. I've sent further queries regarding it to NoNoTech.
    Thanks for sticking with me.
    No the problem is not solved. ICS refuses to be disabled from Computer A. Still cannot ping to or connect to Computer B from Computer A. When I run the wizard on Computer A it finishes up telling me that the ICS connection will be established, which of course is not what I want at all.
    Here's another bit of guess work. Computer A has a second network adapter which is physically present but which has been not only disabled but also uninstalled. It will be a pain to disconnect everything and open the machine up and physically remove that old card, but I will do it tomorrow if you think it's possible that the presence of that dormant adapter is somehow making the computer think that we want to use ICS. Somewhere tonight I read that ICS is only enabled when the computer has two or more adapters.
  • Microsoft Master
  • 4,737 Answers
Please try this.. first ping the other computer, in your case, ping computer "A" from computer "B", if it's successful, then open the Network Connections from the Control Panel of the Computer B > click "File" on the menu > New Connection > Next > Set up a Home or Small office Network > Finish another wizard with the name Network Setup Wizard will open up, click Next > Next > select "This computer connects to the internet through a residential gateway or through another computer on my network" > Next and provide the description and name of your computer, then Next and provide a Workgroup name > Next > Turn on File and printer sharing > Next > wait for few minutes and select "use my windows xp cd" > Next > Next > Finish, you'll be prompted to restart your computer for the changes to take effect. Restart your computer B and now run the same procedure on Computer A, but at this point, you have to use your Windows Xp cd/Dvd. Insert the Cd/Dvd in your Cd/Dvd-rom drive, after the autoplay runs, select "Perform Additional Task" and again click on "Set up home or small office network" and proceed with the onscreen instructions. After you are done with the process, restart your computer and ping from Computer A to Computer B, hopefully, the ping should be successful. Now ping Computer A from Computer B, this should also work fine. After you are done pinging, you can test the connection. If you have further problem, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 02, 2010
  • 2 more comments
    Thanks for your guidance, Nonotech, but I'm a bit confused.
    I have already run the network setup wizard several times, on both computers, but without inserting the XP CD. The instructions on the Wizard screen said to use the CD if the second computer is NOT running XP.
    Both my computers are XP Pro with SP2 and the setup wizard is available on both. Does this make a difference? One problem seems to be that on Computer A the wizard thinks I'm using ICS, because the ICS connection pops up when I start the Wizard. Is that your point? That if I run the wizard from the CD it won't get distracted by the ICS?
  • Lebanon Raingam
    Lebanon Raingam Aug 03, 2010
    I am sorry for the late reply, actually, I had been to take some rest. Hope you'll forgive me for this.
    Well, there are rules and regulations with Networking (computer networking), so following only the instructions on the screen is not suitable sometimes. We need to implement the theory of Logical Network.
    In your case, when I told you to insert the xp Cd on the other computer, it's only to set-up the same settings on both the computers. If the two computers have different Microsoft Operating Systems, I would suggest you to make a floppy-disk when you were prompted by the "new network setup" wizard at the finishing point of the first setup. What i mean is that, if the two computers have different Microsoft Operating System installed, and you are running the setup on xp, then it's not possible to use Xp Cd on another computer with another Microsoft Operating System installed, in that case, you have to make a Cd or floppy with the Wizard.
    As soon as you run the wizard on computer B, ICS is already activated, which means computer B is going to access the internet through another computer's network (in your case, it's not the computer A, but i supposed it myself to the server between them).
    I don't think ICS is related to your problem, your only problem could be setup issues. ICS is another different connection type, and you can enable or disable it from the network properties.
    But for now, my main intention is your problem, whether it's fixed or not. Hope you can let me know.
    Good luck.
  • Lebanon Raingam
    Ok...this time let's go deeper to the network setups.. I have few questions to ask, hope you can give me the answer,
    1. How is the router connected to the Internet? (is the line directly plugged in or is there another modem?)
    2. Is there another switch or hub that comes out from the router to connect the two pcs or are the two pcs connected to the router on different ethernet ports?
    3. Is the connection required to access with a username and a password to get connected with the internet?
    4. Suppose if the Computer A is directly connected to the router, how is the internet connection accessible from Computer B, is it sharing?
    Please don't mind, this time, we need to get restart from the beginning. I hope, one of the two installed Lan Card is onboard and the other is on Pci Slot. If so, disable the onboard from the bios settings. (if you have problem doing this, let me know, i am assuming you can do this). This must be a simple problem, but since I can't physically or virtually access your system, we have been upto this. Well, just send me the answers and I'll definitely help you fix it with the easiest method.
    Good luck.
    Thanks once again.
    1. Router directly connected with coax cable to the FIOS internet connection.
    2. Each PC is directly connected to its own ehternet port on the router.
    3. No password or user name needed to access internet for either computer
    4. Computer B is directly connected to the router and finds the internet there. Like wise Computer A finds the internet through the router. And B can access shared files on A.
    IOW, this is all standard router setup.
    I have disabled and uninstalled the unconnected and unused adapter by using Device Manager, but it comes back up. I suspect it is not onboard but exists physically in another slot and may be causing my problems even though it is not connected to any cable. I plan to close the system down and look into it today.
    Thanks.
    President:
  • 2,559 Answers
You need to go into the network setting in computer B and set it to discoverable and make sure that both have matching network settings
  • 2 more comments
    Thanks, but I've done all that.
    Computer A can't even ping Computer B, although B can ping A.
    When computer A tries to access shareddocs folder on B, it gets message network path not fouind, or workgroupname is not accessible.
    The problem maybe the ICS which keeps on popping up in my Network Connections screen, even though I know it shouldn't be active when I'm using a router. I removed it (AddRemove/Windows components) but it comes back when I run the Network setup wizard.
  • Randy Hough
    Randy Hough Aug 02, 2010
    Go into the ics settings and select exceptions and check for core networking and make sure the box is checked.
  • Randy Hough
    The problem is that both computers are set to be the host and only one can be.
What is my network is it my email this is all new to me
Allen,
Your network is all the devices you have connected in your home to the internet basically. your network starts with the modem that your internet provider installed in your home and that can be either a cable tv modem or a dsl modem from your phone company. Next would be your router if you have one and that can be a wireless router that is connected to your modem. The router provides some security to your home network as it will hide the ip address of your home computers from those out there searching for a system to break into, Your home network is called a LAN ( local access network) The modem is connected to the WAN which is World Access Network and this is the ip address that is given to you by the internet provider. So, anything you have plugged into your router such as a laptop, or desktop pc makes up your own home network. Your router will give each device a private IP address and they always default to 198.168.1.1 and the first computer connected to the router would be 198.168.1.100 and then the next computer would be 198.168.1.101 and so forth. Most routers will handle up to 250 computers and the IP address will sequence up in numbers all the way up to 198.168.250. most homes have maybe two or three computers at the most. Things like Ipads and Iphones using your wireless router will also be given a ip number in sequence. Open a command prompt window in your computer ( you will find it in the accessories tab) open the command prompl and in this window type ipconfig and then you can see the IP address your internet provider has given you at the top and then the IP address your router has assigned you there also. Barnes and Nobles has some great books on computers and they have an odd name, but very easy to understand. They are named PC's For Dummies and other tiles also and very easy to understand and very helpful if you want to learn more. Regards, Dennis
Feb 27, 2015 | Roku Streaming Stick
Connected to wifi but no internet connection
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
Oct 24, 2012 | Cisco Linksys WRT54GX4 WirelessG Broadband...
Does the acer aspire z5700 desktop have a built in wifi router or do i need to purchase and set up a router to enable home sharing network?
While it doesn't have a built-in router, it DOES have a wireless adapter built in. So if you were to purchase your own router (or rent one from your ISP), the computer would work fine with it.
More details on your computer here:
http://reviews.cnet.com/desktops/acer-aspire-z5700-u2102/4507-3118_7-34132723.html?tag=doormat;rnav
May 02, 2011 | Computers & Internet
Although my Asus once recognized my home wireless router, when Comcast sent us a new wireless router to use and a new home network was set up, my computer no longer was able to connect. I can access...
To connect to your wireless router, it needs the router's wireless settings configured and also the wireless cards in all the laptops and or computers needs to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2011 | ASUS Wireless (90-c1i010-00xay)
What is the network security code so I can go wireless? right now I am connected with the yellow cable to the router
Do you have a wireless card in your computer? the card must be in the machine to use it wirelesslly. The router only goes between the modem and the computer. You enter your wireless security when you set up your LAN, on the routers home page which is in the manuel that came with the router
May 21, 2010 | Actiontec GT704WG Wireless Router...
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
http://www.microsoft.com/windowsxp/using/networking/expert/crawford_02april22.mspx
Oct 27, 2009 | Computers & Internet
I had 4 computers on my home network. Unfortunately, my granddaughter took it upon herself to crash the main computer & somehow make my network go offline & unsecured, while creating a new secured...
hi
best thing may be
uninstall the router software first from all the computers and may install the router software first on the main computer then connect the router as per the instructions and then from the network neighbourhood create a disk to create a home network
cheers
pls rate if this was any help
Jul 13, 2009 | Computers & Internet
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
I have cable modem along with the Linksys wireless - G Broadband Router. Added another PC to my home. Purchased Linksys compact wireless-G USB adapter. Installation went fine and able to connect to the...
You should have an RJ-45 cable connected from your ADSL modem to your router's internet RJ-45 plug then download network magic or similar software to input your user name and password on the router. this way you'll have internet even if your computer is turned off.
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Weak connection on one computer in network
set the wireless channel for you router to the maximum level and save the changes
Nov 13, 2008 | Linksys Wireless-G WRT54G Router
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
