Question about Refrigerators
We had to take of the doors on a whirlpool sie by side refrigerator. On the side with the water line going into the door, we had to pull of the grill on the bottom and disconnect the water line. Now when you try to hook the water line back up, it will not stay in the two sided connector.(the side with the red ring around it)Can you get a new connector for it?
    Scholar:
  • 150 Answers
Yes easy this is called a "john guest" fitting probably after the now fabulously wealthy man who invented it. push the ring in BEFORE you remove the tube and you can use them again. availabe @ hardware and appliance supply stores everywhere
good luck!
Posted on Apr 25, 2008
GE side by side leaks water from underneath when you use the water from front door
you need to remove the toe kick panel grille below the front doors on the refrigerator behind this grille there is a connector and it can come loose,also possibly the water valve in the lower rear behind the back panel can leak,have a helper press the door paddle for water and check all these areas for leaks,if it leaks from the door stem where the water line goes up the door to the dispenser,then you will need to pull new hose up to the dispenser from the collar mentioned at first,some refrigerators can not have new hose installed due to the door has been foamed internally at the factory and cant be dis-assembled,then you would need a new door with the hose installed
Apr 08, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Need to change water filter
Hi Mr. Callaway. I understand you need to change the filer in your refrigerator. Here is a list of YouTube videos we offer to help you:
http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/0/lTVfbVkEINIReplacingrefrigerator grilleb>http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/1/C_RBfawcyJ4Replacing interiorSide by Side(upper right) water filterb>http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/2/Cj6QRMrEXmUReplacingFrench-door/Bottom Mount refrigerator filter b>http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/3/CPZgNYxFjjsReplacingIn-Grille Filtersb>http://www.youtube.com/user/whirlpoolcorpcare#p/c/724AE2877520B916/4/D2W8jNl5PYsPurging waterlines
I hope this information is helpful. Sincerely, Melaine, Whirlpool Socail Media.
May 05, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Disconnecting the waterline
Hi, If you remove the grille below the doors, you can see a plastic water line passing through the lower hinge. Follow the line back about 6 inches and there should be a quick disconnect. It may be a screw type or the kind that you push down a small ring to get it to release
Apr 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Un hook the water line from door on whirlpool fridge gold..has elbow from door to main unit.
Push in on the end ring , pulling the tubing out at the same time . If you have the blue connector with white end rings , Push in on the ring oan pull out the tubing at the same time .
Oct 02, 2009 | Whirlpool ES5FHAXS Side by Side...
Need to remove front panel of whirlpool side by side cause water
I ended up running a new line. Was very simple. Just disconnect the old and pull it out. Slide a new one in and connect. So simple.
Jul 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
May 17, 2009 | Whirlpool ED2FHEXN Side by Side...
Water running from under front grille of whirlpool side by side
it should be the water line,, Under there is a coupling and also the hoses that run to the water dispenser. Pop off the toe kick and have someone turn on water slowly while you look for thesource of theluek. Good Luck
Dec 26, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Removing Doors on Whirlpool Gold GS6NHAXVQ side by side fridge
remove the kick plate (lower grill) on the freeezer hinge is a tube folow that tube to a disconect, unscew the nut then remove the nut from the tube then remove the top hinge and lift the door off the lower hinge threading the tube through the lower hinge.
Dec 24, 2008 | Whirlpool GS6NBEXR Side by Side...
My whirlpool refrigerator is running water on the floor
the water line runs thru the bottom hinge of the left side door and its covered up by a grille at the bottom at the front of the unit. and or the drain line is clogged up or frpozen in the freezer compartment. try these things and good luck.
Dec 23, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a side by side refrigerator/freezer. a water drip runs down the grille on the freezer side. a small amount. we cannot locate where the water comes from. Can you help?? model #ed20tqxfn00 Al...
If you have ice and water in the freezer door it would appear that the water line going to the water dispensor has a leak. First check where the door hindges at the bottom as this is where the line runs from the water container located in the fresh food compartment to the water dispensor in the freezer door.
Jul 07, 2008 | Whirlpool Refrigerators
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
