Windows(seven ultimate) not recognized the T50 printer. But the windows XP recognized it correctly. What can I do?
  • mahdyramazan Aug 02, 2010
    Well I have used that driver in the epson site but it doesn't recognized either.
    and also I have used the same port in windows Xp and it worked(With the printer CD installation)
    and also I can see the printer in the Device Manager but when I choose Update Driver and then find from pc( online can't find) it finds the driver on Cd but says that one of installation can't perform now!
  • Computers & ... Master
  • 5,528 Answers
Do you mean the Epson Stylus T50? That should be compatible. Try a new USB cable and a different port. Check if a known working device connects; make sure the ports are not off for driver problems, security or power savings (laptop). One is under the Device Manager (Control Panel > System and Security) and the other is in the Advanced settings from the Screen Saver.
Software is available at http://www.epson.com.sg/epson_singapore/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_Photo_T50# .
I hope this helps.
Posted on Aug 02, 2010
  • Cindy Wells Aug 02, 2010
    The Microsoft Compatibility Center indicates that the T50 is compatible without any Epson drivers. The Win7 OS has an appropriate driver; check Windows Update for the update if using the USB port (if you do not have it set to automatically download and install for new hardware). (This is a variant of the search the network for a driver.)
    The CD not working isn't surprising, Windows has changed its installer a lot since the printer was first released. The website I pointed you to had other software that was potentially useful.
    Since the printer is visible in the Device Manager, do you see a yellow triangle with an exclamation mark or a red triangle with an X? What printer status do you see (online, offline)?
    Cables are still my first issue with any non-functioning hardware. Try a direct connection instead of a print server or USB hub. (I have had more installation failures due to a bad cable than any other problem.)
    I hope this helps.
I CONNECTED THE EXTERNAL HD (HDS5C3015ALA632) UNDER WIN XP, NO PROBLEMS. THEN I CONNECTED TO ANOTHER PC WITH WIN 7, PC DOES NOT RECOGNIZE THE HD AND ASKS TO FORMAT IT. JEAN FRANCOIS BELGIUM
It is because your computer which is windows xp is not able to be updated to windows seven. And when you format it you will loose everything xp. But then you can put everything windows seven on it.
Sep 11, 2011 | Hitachi HDS5C3015ALA632 15 TB Hard Drive
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I had same problem, even if I download de cjb3500_4500en the processo goes on but when I put to configure wifi (orange) they ask me to put a usb cable, but on actives the button do continue if the USB was...
You did a nice job trying out other ways to install the printer successfully. However, it's weird that 3 computers are not recognizing the USB connection. Make sure that the USB cable is plugged in correctly (in the right position) in the USB port of the printer.
Next, use the correct driver that is compatible with your computer's operating system. You may need to uninstall the existing software before reinstalling the new one. Instructions on how to uninstall the Lexmark software available at http://bit.ly/8ZH59T. Then, you can download the drivers at:
If problem continues, contact Lexmark technical support.
Oct 10, 2010 | Lexmark X4550 InkJet Printer
Printer noy recognized by windows xp after 5 years
Im using that same printer on Windows 7 Ultimate. Works fine. Try uninstalling and re-install drivers after you reboot.
Feb 04, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
Is it viata ready or what os do i need for epson tm-u220pb printer
The requirements for epson tm u series printers are.....
Windows XP, Windows 32bit: Microsoft Windows XP Professional 32bit SP3 English, Microsoft Windows XP Embedded 32bit SP2 and Microsoft Windows Vista Ultimate 32bit SP1 English
Windows 64bit: Microsoft Windows Vista Ultimate (x64) SP1, Windows Server 2008 Standard (x64)
Aug 10, 2009 | Epson TM-U220PB Matrix Printer
Unable to install lexmark 8300 series
You will be able to download the correct Vista software from here:
www.lexmark.com
Click "Drivers" and follow the buttons for your printer name and model number.
Aug 05, 2008 | Microsoft Windows Vista Ultimate Edition
PANASONIC KX-FLB802
Printer Panasonic KX-FLB802 Driver for this printer to work with windows vista home ultimate cannot be found. Does a driver exist to suite Vista and where can i find it. Many thanks
Jun 16, 2008 | Panasonic KX-FLB801 All-In-One Laser...
Computers & Internet Logo
93 people viewed this question
Alun Cox
David Payne
David Payne
