Question about Boating
Mercury outboard problem
Something seems to be slipping in the lower unit
  • 5,687 Answers
If you have a spare prop try it. The prophub of your current prop may have a bad Rubber bushing. There are some OMC units which have a 2 piece design that still has the Rubber bushing but the prop is a separate piece and the inner hub is sold separately.
Most Mercs have the Rubber hub as part of the prop. The Rubber hub in any case is taking the place of a shearpin. The Rubber starts to slip or crumble and then you can't go anymore. Sometimes the damage is visible but only sometimes.
For the 1 piece system the Hub needs to have a new Rubber bushing installed at a Prop shop. With luck, the prop is your only problem.
Posted on Aug 04, 2010
  • lighthousefa Aug 04, 2010
    already tried a prop .. that was my first thought also, I also readjusted linkage as I just replaced water pump ...... I am a machinist with lots of mechanical back ground.
    I see in a manual the gear set on prop shaft and a shifting dog and pin.
    Not having been inside on of these LU not sure exactly how this works or
    if there is something typically wears and allows it to slip.
    Just bought this boat "used" have tried it after each attempt of fixing so far and
    each time it work fine for 10 to 20 min. then slips with half throttle or more
I have a 110 mercury 9.5 hp not sure of year
This Mercury section is for cars not outboards. Web search for Salvage parts for outboards.
Jul 25, 2017 | Mercury Cars & Trucks
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
I have a mercury 75hp outboard ser#OD020354 would like to know what year the motor is
QUESTION:
How can I determine when my outboard was built?
ANSWER:
Every Mercury outboard has a serial number label located on the transom bracket area of the engine. The latest serial number labels display a 2-digit number in a box at the lower right portion of the label. These digits coincide with the last two digits of the year in which the outboard was manufactured. For example, if an outboard was manufactured in 2010, the number "10" would appear in the box at the lower right portion of the label.
May 01, 2017 | Mercury Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Nov 11, 2009 | Quicksilver Quiksilver - DEEP 300 - SILVER...
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Gear shifter for 40 h. p. mariner outboard
With your lower unit off have someone shift the engine into forward while watching the gear shift select shaft's rotation,let gearshift remain in forward,now place your lower unit in forward and reinstall. In the future just put engine in forward when installing a water pump as there won't be a need to move gearshift
Jul 23, 2009 | 2004 Mercury Mariner
Mercury 20Hp impeller/water pump location
It is located inside the lower unit housing. They are fairly easy to replace. Most Mercury authorized service stations will charge around $120 for this task.
Triton72
Mar 26, 2009 | Sport & Outdoor - Others
Boating Logo
256 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
