Question about Garden
Draper Power Wash 2121. Worked ok yesterday. Today just seems to be power to the unit when switched on with a bit of a hum -but with little pressure nor the normal loud working noise. Suggestions welcome. Many thanks.
SOURCE: loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Posted on Mar 21, 2007
daverh
  • 117 Answers
SOURCE: Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Posted on Sep 24, 2007
honeymokey
  • 3113 Answers
SOURCE: Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Posted on Apr 08, 2009
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
  • 4090 Answers
SOURCE: Karcher B402 pressure washer Motor runs as soon
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Posted on Jun 22, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Signal not connecting
https://contactus.netflix.com/contactus?locale=en-PS
Jan 16, 2014 | Netflix
Sony dab fc7 wont power on
Two thing here.
#one the internal fuse has blown unlikely as the standby light is powered.
Two the power supply unit or switch is faulty.
get some one electrical component with the unit unpluged open the case and check any internal fuses have not blown.
Two check capacities on the power board these are large cylindrical shaped objects. These can dry out and or exploded if faulty relatively cheap to replace.
Second check the power switch actual powers the unit again someone with a multi meter and electrical compertent.
It is probably worth replacing either a capacity or switch anything else may prove false economy
I have replaced power board on other units but to be honest unless the unit was very expensive I would buy new
Dec 06, 2013 | Audio Players & Recorders
I left my fender frontman 65r on for over a year and yesterday a gentle hum for a few seconds then a loud hum for a few seconds more then no more power to the unit. I opened it and troubleshooted it around...
Why was it on for over a year :D Has anyone replaced the fuse? In the service manual I found it has to be only 2 Amps! Okay let's solve the problem. The power transformer was overloaded which caused the broken winding. It is still overloaded what can be heard by the hum sound. First thought was to check main capacitors or better just replace them! If the hum gets louder, they might also become warm. Check voltages after bridge rectifier and smoothing circuit. They should be +/-42 V (TP3, TP4) and +/- 16 V (TP5, TP6) Let me know which of them is faulty Cheers
Feb 11, 2013 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Unit does not want to turn on. Power to switch, makes a noise when you turn the knob, but machine does nothing?
Sounds like either the unit's control board or timer is not communicating correctly. If you at all hear a humming or buzzing noise, the control board may be having issues with the motor of the unit. You would need a professional in this case to move forward.
Sep 23, 2012 | Frigidaire GLGR642A Gas Dryer
Temperature on display will not go down
HI PAULA.this is too new but the fact that it went wrong after the power cut indicates that the power surge has damaged the pcb board.try manufactures warranty.good luck.Ali
Aug 21, 2012 | Frigidaire Refrigerators
Power wash 2130
google it and see if you can download it as a pdf file.
May 17, 2012 | Draper Hand Tools
Worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Feb 07, 2010 | IBM ThinkPad T40 2373 Notebook
Worked fine yesterday, today zilch !!
One computer I fixed had its internal power regulation confused. With the AC adapter plugged in, holding the power switch down for twelve seconds, then pressing it again, switched it back on. This sort of problem can come from a variety of causes, though. There is an internal power distribution chip which could have received a static electric shock or power surge and gotten cooked. The RAM could have gone bad. The socket where the adapter plugs into the computer could have been cracked loose. Check the power switch and then RAM first, and write more if that doesn't fix it.
Jan 05, 2009 | Toshiba Satellite M105-S3041Notebook
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
