Question about Fisher and Paykel DEGX1 Electric Dryer
I have a FP Electric Dryer DEGX1US and it is squeaking like crazy! Can you help?
    Brigadier General:
  • 3,301 Answers
More than Likely the rollers that hold the drum,, you have to remove the drum (be sure and look before to see how the belt tensioner is set up) pull the drum, Lube the rollers , and reassemble
Posted on Aug 02, 2010
5 Suggested Answers
  • 178 Answers
SOURCE: Dryer Squeaking
A couple of possibilities, your belt could be getting worn or the dryer motor pulley is slipping causing it to squeak. if you send me an e-mail to robert_fawbush@yahoo.com , I will be able to send you pictures of your dryer to make it easier for you to troubleshoot and do the repairs on your own. Major money saver.
Posted on Apr 21, 2008
  • 73 Answers
SOURCE: squeaking sound on new samsung dv448aew dryer
first off you need to put your foot down and tell them to replace the belt or the adjuster .dont let them leave until they have satifyed you
Posted on Mar 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Intermittent Squeaking
You know how when the pads on your car get worn they start that noise? Well the bearing that holds the tub has a metal bracket. When that plastic wears down it begins to makes those noises. If left alone the metal bracket will eventually cuut into that drum bearing like a guillotine. I have pictures. Have the women and small babys leave the room: Click (HERE)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 08, 2009
  • 5 Answers
SOURCE: My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Posted on Apr 01, 2010
I have a squeaky dryer
You have a belt that goes around the barrell and the belt has a tension pulley on a tension arm. Those pulleys go bad. It is an easy fix. It takes longer to get to the pulley than to fix it. It is a 4 minute fix, but it will take a while to take off the housing to get there.
May 08, 2015 | Frigidaire FER641FS Electric Dryer
Fisher paykel dryer DEIX2 squeaks when drum rotates
I've had the same issue with my FP washer, thanks for the tips!
Jan 17, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
DEGX1US my dryer is running but there is no heat it is only 6 yrs old can you help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jun 26, 2011 | Fisher and Paykel DEGX1 Electric Dryer
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
Dryer squeaks like crazy.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Apr 01, 2010 | Frigidaire Electric Dryer
My LG DLE2514W electric dryer starting making a squeaking noise at the end of a drying cycle last night. After letting it sit for over an hour, started the dryer back up and the squeaking noise came back...
heatman101
vciku
Jun 29, 2009 | LG DLE2514 Electric Dryer
Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
May 12, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Squeaking sound on new samsung dv448aew dryer
Mar 24, 2009 | Samsung DV448AEE Electric Dryer
Bosch Dryer squeaking noise
I have not seen any service manuals online. The squeak will possibly be a rubber bush used to silence the machine. If you get it stripped down you should be able to locate the squeak by carefully applying pressure in different areas and the squeak should go... then hopefully you will have found the culprit.
Mar 15, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
102 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
