Question about Refrigerators
I have ice forming on the top of the freezer door and on the to of the freezer. What is causing this and how can I fix it?
  • 4,793 Answers
Ice forming on the outside of a door is a sure sign that the door seals are not air tight(flat against the body)use a hot cloth to mould the seals to fit......
Posted on Aug 02, 2010
Icy crystals forming on food in freezer
Ice crystals forming on Frozen items in the freezer is an indication of an air leak caused by either a bad seal leaking seal or an open door to the ice maker Ice chute door
Appliance 911 Sea Breeze
May 17, 2016 | Frigidaire Refrigerators
There is ice forming on the inside back wall of the freezer. What does this mean? Would it cause the refrigerator alarm (beeping noise) to go off?
It usually means that your door is either not closing properly or the seal is deformed. Moist air is getting in and condenses on the coldest surface at the back of the freezer. Check that the freezer is not too full (stopping door from closing fully) and check the door-seal.
Sometimes it is caused by icing of the thermostat. Ice is a good thermal insulator so the thermostat does not switch and the freezer keeps running constantly. Make sure there is adequate air circulation and no ice around the thermostat.
Defrosting usually fixes either problem.
Oct 13, 2014 | Refrigerators
Excessive "fog" in freezer causing
Check your door gasket. Cleaning the gasket should help it seal again
Nov 27, 2017 | Maytag Refrigerators
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
Frigidaire frostlfree upright freezer ice forming top interior door
Not sealing. warm air hitting cold air causing frost. also, door frame heater may not be working. most frames are "warm" to the touch. normally called an "anti sweat" heater.
Jul 15, 2008 | Freezers
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice on top of freezer and top shelf of door
IT SOUND LIKE YOU HAVE AN AIR LEAK IN TOP OF GASKET,THE GASKET HAS A MAGNET IN IT ,YOU CAN USE A HAIR DRYER TO SOFTEN THE RUBBER UP TO SEE IF YOU CAN GET THE SEAL BACK TIGHT,BE CAREFULL NOT TO BURN THE GASKET OR YOURSELF,THANKS-MIKE
May 27, 2008 | Freezers
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
