Good Afternoon, We have a Kenmore Elite HE4t which works just fine except that when going to do a load the next day there are several inches of water in the bottom. No error codes. Running Drain and Spin empties it out and the next load runs just fine, leaving no water in the unit. But the next day the water is standing in the bottom again. Water is clear. Thanks for your help.
  • 171 Answers
Sounds like the input valve is leaking, not shutting entirely when it's supposed to.  most probably will need to be replaced.  have done numerous times and always solves problem.
Posted on Aug 02, 2010
  • 4 Answers
I also had the same problem and replaced the input valve and now it is working perfectly, You can do it yourself very easily for around $50. I suspect hard water deposits are to blame for mine.
Posted on Aug 27, 2012
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore HE4t gas dryer will not heat. One load
The Sensor for heating element cut-off is bad. It wrongly detects the unit is overheated so it signals to inhibit the gas valve not to open. Since it is not opened, gas is not burnt through the manifold hence not heat why the machine is tumbling. Good luck.
Apr 18, 2010 | Dryers
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T won't stop on the Spin Cycle. Stays
Replaced the relays with the 16Amp rated ones from Digitel.
Aug 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
176 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
