Question about Samsung LN52A850 52 in. LCD HDTV
TV showing picture but no sound
My Samsung TOC LCD TV is showing picture but no sound. I have muted and unmuted as well as switched the TV off and on.
  • 11,361 Answers
Check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit which you will need new main board. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 03, 2010
  • Samsung Master
  • 8,457 Answers
Could be the cable box is bad,u should check all other tvs in the house are find,if it have sound? Yes,tries unplug the tv and the cable box about an hour.Replug both back in.Let the cable box upgrade it software.The tv it now resetting back to it factory setting.Go into the tv Menu,go to AUDIO setting,go down to reset the AUDIO setting back to factory setting.The tv should have sound now.Not,than the Tuner board is dead,that the board take in the tv broscasting cable signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Aug 02, 2010
My Samsung tv is suddenly muted and I can't unmute. How can I fix this?
The volume buttons have 3 functions... down and up and straight down... that's mute. if that does not fix it go to menu.. the gear icon click on audio, likely we switch to an external sound device like DTS Amplifier...
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Nov 22, 2017 | Samsung Audio Players & Recorders
I muted my tv it wont unmute i have no sound help
make sure your remote works, replace batteries and check again with tv.
Jul 05, 2015 | Apex Digital LD4088 LCD TV
Sony KDL-40bx450 no sound
Two things to do:
First see if you have sound with a DVD etc connected to a rear input.
Second look in the menu to make sure speakers not switched off or to external
Dec 13, 2012 | Sony KDL40BX450 40" 1080p LCD TV...
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
No audio
went into setup, tv and kept hitting the mute then unmute it finally took. Not sure what was wrong with it since I had already done that several times. The two audio outputs on the side of the tv do not work like it says in the manual for surround sound. Its definitely a cheap tv.
Jun 21, 2009 | Olevia 227-S11 27 in. LCD TV
No volume on my Samsung 50" flat screen
Go check up the settings. First disconnect all appliances and then reconnect when power off. Configure connection when power on.
See your manual. You use the analog tuner or digital cable or satelte receiver to watch TV. If external digital decoder check your settings there. They are independend and might be low or muted sound level or incorrect setting.
Apr 14, 2009 | LG 42LC2D 42 in. LCD HDTV
Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Mar 20, 2009 | Televison & Video
Permanent mute on tv screen
Unplug the TV for 30 seconds or more. plug it back in and find the help menu and see how to do a system reset.
Nov 17, 2017 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Samsung LN52A850 52 in. LCD HDTV Logo
544 people viewed this question
Jerry Greenberg
Jerry Greenberg
