Question about Kitchen Ranges
My new FGB24S5AS oven won't heat to the corrrect temperture
  • terri416 Dec 24, 2008
    Mine will not heat up at all. Only 2 years old
  • 1,073 Answers
It is under warranty call for factry service
Posted on Apr 25, 2008
Jenn air gas oven won't light off/heat up
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 13, 2011 | Jenn-Air Ovens
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
Newhome 1000dfdl main fan oven appears to stay at the same temperture what ever the setting
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element whilst the temperature light remains on.
but if the temperture light is off then its likely to be a faulty thermostat
Dec 18, 2009 | Stoves 1000DFDL Dual Fuel (Electric and...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
The oven is thermador ct227ncprs01
if the heating ligth is not coming on it will be must likely an exaust problem either the sail switch is bad or it has a bad fan exaust motor.
Mar 18, 2009 | Ovens
Small oven explosions
check and replace your gas regulator to your burners in your oven
Mar 16, 2009 | Thermador P304CS Gas Kitchen Range
Maytag Range CRE9800ACE
have you checked the status of the thermostat? there is a possibility that it is the one causing the issue.
Aug 06, 2008 | Kitchen Ranges
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
Kitchen Ranges Logo
63 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
