Question about Schumacher DSR ProSeries Battery Charger - 250/65/35/5 Amp, Model# PSW-61224
MY CHARGER KEEPS CLICKING FROM CHARGING TO CHARGED AT INTERVALS IS THIS THE WAY IT SHOULD BE WORKING OR SHOULD IT STAY CHARGING
My Tablet is on charge and the screen icon shows it is charging but the Charge % Icon is staying the same
Try a different battery charger.
Maybe you are using a battery charger of a phone.
They have the same plug but different Amperage.
Usually tablets have more powerful battery charger than phones (2.1A instead of 0.5/1A).
The battery charger that you are currently using seems to have enough power just to keep your tablet alive, but not enough to charge it.
You can check on the data written on the battery charger's body the maximum amperage.
Jul 16, 2016 | Amazon Kindle Fire HDX 7
How does the charging system on a 1969 Honda 325 cc motorcycle work to keep engine running?
I think you mean a 69 CB350. It sounds like you have a bad battery since the battery charger won't charge it.
On this bike there is an alternator and rectifier that combine to charge the battery whenever the engine runs. If the battery won't hold a charge, the charging system wont work.
Replace the battery.
Sep 26, 2014 | Motorcycles
Wireless charger not charging phone
Normally blinking means charging and the light will stay/keep ON once it completed charging.
May 15, 2014 | Wireless Solutions Plus Wireless Solutions...
I have got apple macbook pro unibody , my charger light is blinking and not charging battery while my laptop is on but when i shut down my laptop its connecting and disconnecting for 10 seconds interval
Try charging your laptop with a spare charger. If your laptop is still under warranty, make an appointment with a genius bar representative at a local Apple store to diagnose your laptop's issue and replace the charger.
Warning!
Do not use the USB ports to charge any external devices from your laptop! Instead use the chargers they were packaged with.
If the spare charger doesn't work after an hour of charging you will have to reset the System Management Controller with the Mac turned off:
Press Shift-Control-Option-Power key combination.
Release and press the power button.
If resetting the SMC doesn't work try resetting the PRAM. Keep in mind that you have to enter the key combination before the grey screen appears!
Reboot your laptop.
Immediately hold down Command-Option-P-R combination.
A reboot sound should confirm the reset.
Aug 26, 2013 | Apple MacBook Pro Laptop Computer with...
Battery discharge quickly
Sounds like it's time for a new battery. Rechargeable batteries often hold less and less of a charge as time passes. Especially if it doesn't become drained and charged at a regular interval or if it stays on the charger all the time. (This is untrue with the new Lithium Ion batteries but the charge will diminish over time.
Jan 25, 2011 | Canon PowerShot A470 Digital Camera
Battery and charger not working correctly.
u r charging,but the charging stays for a few minutes,go for a new battery and try
Mar 04, 2010 | Optics
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
Camera Will NOt Charge
go for the new charger. Keep the battery, always good to have a couple of batteries[I have 3 lions and when I was using AA's I had 6 sets of 4.
Aug 19, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Schumacher DSR ProSeries Battery Charger - 250/65/35/5 Amp, Model# PSW-61224 Logo
65 people viewed this question
Top Schumacher Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Schumacher Hardware and Accessory Expert? Answer questions, earn points and help others
