Question about LG WM-2277HW Front Load Washer
Washer does not drain, at that point in the cycle the machine makes a clicking noise.
  • 343 Answers
You may have a blocked or jammed drain pump filter.
Check the drain filter as described in the manual. Access is via the small hatch at floor level. Make sure the machine has as little water as possible, because it will empty via the pump when you check the filter. Lean the machine back against the wall to help contain what water is in the machine.
Unscrew the pump filter, check and clean. Also check that the impeller is not jammed by a coin or a hairclip or similar. (That could be the clicking noise.) Replace filter and test. Sometimes the impeller comes off the pumpshaft. In this case the pump motor would need to be replaced by a serviceman...
Good luck....Nomess
Posted on Aug 03, 2010
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Washer wont drain
Hello shirley_dods - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Try setting the cycle to spin cycle only. Will water pump out? If it does not, then the washer could possibly be experiencing a communication error with the control board, faulty pump, timer or door lock assembly. At this point, I recommend connecting with a professional to accurately pinpoint any potentially more serious issues.
Mar 04, 2013 | Frigidaire FEX831CS Top Load Stacked...
Splendide 2000S Vented Washer/Dryer makes a bad noise once in the rinse cycle and water will not drain
Check the drain pump. There may be a coin, hairclip , button etc stuck in the blades of the pump. If the machine cant pump out, it wont go through the cycle.
Sep 17, 2017 | Splendide 2000S Vented Washer/Dryer
I have a lg washer that sometimes it drains and other times it doesn't. the filter is clean and when it doesn't drain it makes no noise like it is tied up. it just sits silent. it fails to pump at...
Have you removed the hoses to the drain pump and looked for any kind of obstructions.You will need to make sure there is nothing blocking or slowing the impellar wheel.
Dec 29, 2010 | LG WM-2277HW Front Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Loud noise in spin cycle
Most leaks are associatd with your drain pumps although it can leak from the tub. If its the tube the seals in it are worn if it the drain pump - the first point to check is where the drain hose connecs to the pump otherwise you may need to replace the drain pump
The noise - if its what i am thinking of starts just as the spin cycle stsrts and just as it finishes - usually a clutch problem - worn - parts need to be changed.
Regards
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Washer
relay switch between timing circuit and spin cycle is faulty
Apr 03, 2008 | GE WDSR2080D Top Load Washer
LG WM-2277HW Front Load Washer Logo
598 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
