Question about Philips Magnavox MT1905B 19" TV
The red went out in a storm now alot of green.
  • Philips Master
  • 5,568 Answers
The red may still be there but no longer seen. The green driver transistor has probably failed that drive the CRT.
A multimeter and a little knowledge will find the shorted part, possibly one of three identical PNs mounted on the small board plugged onto the base of the CRT.
If you decide to DIY, be advised that the CRT can hold voltage for many hours on some sets and deliver a nasty shock.
Posted on Aug 02, 2010
How do I know what parts to get to fix it
Have you replaced the lamp recently? they can fail if they are on when the storm happens? Please post your model # for more info.
Apr 21, 2015 | Panasonic Televison & Video
Heater hose diagram
It don't matter where you put your heater hoses, coolent just goes in one and out the other, it don't matter whatsoever. Your problem is that your heater hoses are clogged up. Check where your hoses connected to your engine for blockages. If alot of corrosion is present, you stand a very good chance that your heater core may be clogged up as well. Wouldn't be a bad idea to clean out your coolent system with a good quality flush. Just to show you what i have found, check thes pictures, check red areas for blockages, and "c" is the inlet, "d" is outlet.(don't see why it matters tho)
make sure to check other end of hoses for blockages. inlet side goes to closest connection to waterpump.
Dec 11, 2013 | 2004 Kia Sorento
Air conditioner went out during thunder storm and now only blows out hot air. How can I fix this problem?
check to make sure outside unit is running. power failures can damage alot. if it was running during storm.
Jun 17, 2010 | Bryant 463AAC005BA Air Conditioner
Toshiba 62; DLP 720P- Alot more red and green
You have probably have installed the wrong lamp or you installed a third party/off brand Lamp. If that is the case anything other than a Factory replacement Lamp will have a different color temprature. Install a Lamp that is listed from the manufacture.
Jul 14, 2009 | Samsung DLP HL-P5663W 56" TV
My tv won't turn on after it went out during a
Leave the TV off and unplugged for 24 hours then try it. If it still doesnt work you may need to consult an engineer. The TVs power supply board may have blown due to power surge/spike. I recommend getting a surge protector to avoid this happening in future.
Jul 10, 2009 | Panasonic Televison & Video
Toshiba 56PW8 rear projection - lost sound and picture after powercut
The convergence amps in those units consist of two Sanyo STK392-110 Ic's that get hot enough to fry eggs.. If your storm flexed voltages enough it could have easily shorted the amps and/or take either of two pico fuses in the 24v supply line to the amps... If you're not too tech savy this is one for a reliable shop and not and expensive fix. Two Sanyo Ics and a couple pico fuses should be more than $50.00 dollars and a couple hours of labor to put them in... While they're at it have them check the caps in the hyper module and for any ring cracks in the deflection circuit...
Bill
Jan 09, 2008 | Toshiba 50H72 50" Rear Projection...
GREEN LIGHT KEEPS GOING BACK TO GREEN
Hi Jess......I have one of these TV's but in a 30". Could it be the AC Adaptor? Does yours come with one? My problem is the AC Adaptor stopped functioning therefore I have no power going through my TV. It is frustrating not getting any useful help on this TV. I will never buy a noname again. Would you know or have an 800 number or know where I can buy another AC Adaptor for my 30"? I think your problem my well be similar to mine. Hope this helps and thank you in advance for any help you can give me.
Jul 21, 2007 | Sova Digital DST207-S37C Television
Philips Magnavox MT1905B 19" TV Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
