Question about Kenmore 77062 Gas Dryer
Change drier belt on model number 41794702300 Kenmore stackable
    Scholar:
  • 32 Answers
1. UNPLUG UNIT. 2. On the front of the unit, remove two screws from the bottom panel. Remove it and you will see two screws holding the top panel and door in place. 3. Remove the screws and gently pull up and out on the door panel, INSURE NOT TO PULL ON THE WIRES LEADING TO THE DOOR SWITCH. 4. Remove wires from door switch. MAKE SURE TO NOTE WHICH WIRES CONNECT TO WHICH TAB. 5. Set door aside and you will have complete access to drum. Remove old belt, if necessary, noting now it is around the drum and weaved through or around the tension bar below the drum. 6. Once removed, or if there is no belt, or a broken belt, put the new belt around the drum so that the slack hangs below the drum. NOTE: You will probably see a black mark around the drum where the belt has laid, about in the middle of the drum. Lay the belt on that path. 6A. Lay on your back with both hands available, raise drum slightly to get access to the belt. Take slack in belt, raise tension bar slightly out of the way, bring belt UNDER the pulley on tension bar and put it around the pulley/spindle on the motor. (This may take another hand) Slowly lower tension bar back down to make contact with belt, applying tension to belt. 7. Get the door panel and reconnect the door switch. 8. Start to put door panel in place, while slightly raising drum to fit into position, careful to the raise to high or **** drum out of position off the back rollers or cause belt to slip off. Push door panel into place and put screws in. 9. Once you've got the door secure, test the belt by reaching inside and manually turning the drum clockwise until it seems to turn easily with not bumps. This is allowing the belt to settle into place and insuring it is not going to pop off; if it does, repeat the operation. If it turns easily, move on to... 10. Replace lower panel. 11. Plug in unit and test to insure drum moves freely. If not, you may need to readjust the way the door panel fits in place with the drum, or the belt on the tension bar. 12. If you need further help, please let me know.
Good luck. It's simpler than it sounds. G
Posted on Aug 02, 2010
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
My kenmore stackable is 14 years old with limited use. It was working just fine, until it filled, stopped and then it started producing an odor like something burning.. and none of the settings worked
Probably just a drivebelt has finally failed. Find the model number and google the model followed by 'belt'. Then find someone to change the belt if you can't do it yourself. Not a difficult repair at all. 25301938-wng3opgl1pug32fsc4t4fc4i-1-0.jpgexample
Nov 30, 2014 | Kenmore Washing Machines
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Matag stackable My Drier Squeals loud on start up
could be motor put oil on back baring aka rollers
Jan 29, 2009 | Maytag LSE7806A Top Load Stacked...
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 77062 Gas Dryer Logo
255 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
