Question about Casio FX-115ES Scientific Calculator
When I try to add say 44.25 and 3.50 it won't give me 7.75 it rounds up to 8. How do I get it to stop?
  • 4 Answers
You are in the Fixed decimal place mode.
To change back to a normal mode press the Shift button(top upper left bluish color) and ten the Mode button (top upper right)
You will get a list of items from 1 to 8.
press the 8 button which is normal.
It will ask which normal mode you want. The difference is how it display the output within a certain range of values.
The "1" will show an exponetial format for value beyond 2 so .005 would be 5X10-3.
I would choose mode 2 so that it will only show exponetial beyond -9
Posted on Aug 03, 2010
How to round off 4,318
There are a few steps to rounding.
Identify the column that you are rounding.
Look to the digit immediately to the right.
If this digit is 5 or more, add 1 to the original column, otherwise don't add 1 to the original column.
Make numbers to the right of the original column 0.
Let's round this to the nearest 10s. The number immediately to the right is 8, so we add 1 to the 10s column and make the numbers to the right zeros. I get 4,320.
Good luck.
Paul
Nov 09, 2015 | Office Equipment & Supplies
What is 25,382,872,000 rounded to the nearest hundred thousand
When rounding, we always have to look at the number in the column one to the right of the column that we are rounding to. In this case, the hundred thousands column has the 8 in it. The column to the right has the 7. Since 7 is 5 or greater, we must add 1 to the 8 and set all columns to the right to 0. Thus, we should get
25, 382, 900,000.
Mar 18, 2015 | Office Equipment & Supplies
My rs200 toyota sewing machine bobbin won,t take thread round to lift bobbin thread
At 8 months old must still be under warranty, so take it back before you have any more problems and get a replacement.
Jan 19, 2015 | Toyota Sewing Machines
Estimate by rounding to the nearest hundred
118+146
Round 118 to the nearest hundred. Look at the number to the right of the hundreds column. If it is 5 or greater, add 1 to the hundreds column. If not, don't add 1 to the hundreds column. Make all columns to the right of the hundreds column 0. Since the number in the tens column is 1, we don't add 1 to the 1 and make the 1 and 8 zeros, so we get 100.
We do the same with 146. 4 is less than 5, so we just change the 4 and 6 to 0 and get 100.
We now add 100 and 100 and get our estimate of 200.
Good luck.
Paul
Oct 20, 2014 | Office Equipment & Supplies
How do i round a math problem??
put one number on top, the other one under that. Last figures (if one has more than the other) should be lined up.
Then start adding top and bottom on the left. 4+1 gives 5
then the second from the left 6+3 gives 9 then the thirty from the left 3+2 gives 5
231
364
595
when you have to ad 7+7 it will give 14. Write down the 4 and add 1 to the next sum.
You also can put more than 2 in the row, like
231
645
44
911
1831
Sep 11, 2014 | Mathews Matthews Round-D-Round Production...
I have a very round shaped face no matter how much weight I lose. What kind of hair style will suit me best?
If you have a round shaped face, you need a hairstyle that will lengthen your face rather than emphasize the roundness of it. If you have layers, put them at the top to add height but thinned out under the cheekbone line to give the impression of a narrower chin.
Jan 10, 2013 | Health & Beauty
Head bolt torque settings
Torques Punto 1100 year 1995
1st round: 20 Nm
2nd round: 30 Nm
3th round: add a quarter
4th round: ad another qourter
sequence:
8 6 2 5 10
7 3 1 4 9
This is the 'Fire' engine, also placed in the Uno and Panda.
Oct 08, 2012 | 2005 Fiat Punto 1.2
Having problems with the coffee maker making full cups of coffee. I have descaled the coffee maker with white vinegar like the owners manual says, twice and it still says descale. Occasionally it will...
This usually means this unit is toast:(. if off warrenty you might need to buy a new one. try getting a comercial b140 or 150 as they are a little more robust.
Sep 05, 2011 | Keurig Platinum B70 Coffee Maker
Cover won't go on.round metal strip won't fit on round spindle that turns chain.E-235.Do I need the break bar?It doesn't line up either. DB
Sounds like the chain brake was set when you took the cover off. You need to disengage the chain brake (release it) so the round spindle will fit inside. Look for the two parts (one on cover, one on saw) that match up at the base of the chain brake. You won't be able to fit the whole cover on, but if you can line up where the metal triangular gear engages the chain brake, you can give it a snap to disengage it. What I have done in the past is to line up the two parts and push down on the top of the cover where they meet so as much of the gear is in the chain brake release as possible ( I put a knee on it ) and then give a snap to release it. Be careful though, because the cover part is plastic and you don't want to strip that part of the chain brake assembly. Good luck.
Sep 04, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What are the RPN keystrokes for the following problem: 8%+.9(12.2-5.2)+3%
The problem as written is not well-formed. The leading "8%" does not say "8% of what", and the "+3%" is ambiguous, so I assume the problem really is (( x + 8%) + .9 ( 12.2 - 5.2 )) + 3%, where x is a number entered before.
The resulting RPN key sequence is:
  1. x [ENTER] --- giving a value for the 8% to operate on
  2. 8 [%] [+] --- add the 8% to the previous value
  3. .9 [ENTER] --- push the 0.9 to the stack
  4. 12.2 [ENTER] 5.2 [-] --- evaluate the content of the brace
  5. [x] --- multiply .9
  6. [+] -- add the x + 8% and .9 ( 12.2 - 5.2 ) terms
  7. 3 [%] [+] --- add three percent to the result from step 6.
In case you actually meant ( x + 8% ) + ( .9 ( 12.2 - 5.2 ) + 3% ) - note the difference in the position of the braces:
  6. 3 [%] [+] --- add three percent to the result from step 5.
  7. [+] -- add the x + 8% and .9 ( 12.2 - 5.2 ) + 3% terms.
Note, the only difference is the reversed order of step 6 and 7.
Jan 19, 2011 | HP 12c Calculator
Casio FX-115ES Scientific Calculator Logo
122 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
