Question about Silverlit Toys Blue Air Hogs R/C Havoc Heli Mini Electric Infrared RC Helicopter by SpinMa
Silverlit Helicopter won't take off & only spins in counter-clockwise circle. I've tried everything !
3 Suggested Answers
SOURCE: I cannot charge my silverlit gyrotor helicopter
I purchased this item for my grandson for Christmas.
Right out of the box the chopper would not charge.
Of course I did not find out about this until I asked them how
the chopper working for them.
I purchased this from Sam's Club on line what do I need to do
to get this repaired or replaced.
Posted on Feb 10, 2011
Don3542
SOURCE: My helicopter won't take off,
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Posted on Jul 11, 2011
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
I have a Silverlit toy helicopter that spins out of control. It will not trim anymore. I changed all the blades which did not fix the problem!
check the wires on your rear rotor you they may have come lose.
It did not look like it was spinning in your video...
Jan 25, 2013 | Toys
Ir helicopter only upper wing spinning
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Dec 30, 2012 | Worldtech Devices World Tech 85618 2CH...
World Tech Saturn-X - spins, rudder trim doesn't help
I know what the problem is, i had the same issue right out of the box. if you take the cover off the front you will find the battery. on the bottom of the battery is a 2-sided sticky tape to hold it in place, on that tape the is probably a pulled wire. theres red blue black and white (as well as a thicker red and black that lead to the battery. find the wire that is pulled and solder it to the correct part. for me it was the white cable which controlled the top blades. the helicopter spins because both set of blades should counter rotate and if one of the motors isnt getting power from pulled cable the helicopter will spin and flip. Hope this helped. email me at thedew312@gmail.com if you need more help finding where the wires connect
Dec 28, 2012 | Worldtech Devices World Tech 85618 2CH...
Chopper spins clockwise . How do I fix it
It is spinning around because one of the rotors is not spinning at full speed. This happens when you bump a spinning rotor against something. Determine which one it is by observation or logic (i.e, the one that turns clockwise will produce counterclockwise torque, which is to be balanced by the other rotor spinning counter clockwise. So the counter clockwise spinning rotor is slow) Tighten the screw that holds that rotor that is spinning more slowly. Use the screwdriver that came with the spare parts.
Dec 15, 2011 | JCPenney Gyropter RC Helicopter
Does anyone know where to buy a new main prop blade for the airhog helix 360 r/c helicopter?
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Dec 25, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Dec 15, 2010 | Silverlit Toys Intelli Heli RC Helicopter
Heli spins counter clockwise
See solution 2 for post "How do i fly my spin master air hog rc helicopter?"
Jan 03, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Flew helicoptere twice now spins out of control can't trim at all
make sure the blades and rotors are free from any debris such as thread, hair, and string.
Dec 30, 2008 | Silverlit Toys Original Red Picooz Mini...
Silverlit Toys Blue Air Hogs R/C Havoc Heli Mini Electric Infrared RC Helicopter by SpinMa Logo
589 people viewed this question
Top Silverlit Toys Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Silverlit Toys Toy Expert? Answer questions, earn points and help others
