Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Matshita DVD-RAM UJ-851S ATA Device
This disc drive has worked without a problem since I have had the computer (only about 6 months now) now when I put in a disc it says--- Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 10.
Any Help would be GREATLY Appreciated!!!
  • 11 more comments
  • esdwilliamso May 05, 2008
    I have the same problem, but my computer is not even recognizing my DVD at all.
  • Anonymous Jun 06, 2008
    AFTER 1 AND 1/2 YEARS MY UJ-851S STOPPED RECOGNIZING ANY TYPE OF DISK. I GET AN ERROR CODE OF 39. THE DRIVE IS NOT DISPLAYED UNDER MY COMPUTER. I UNINSTALLED THE DRIVER AND RESTARTED THE COMPUTER. THE DRIVE REAPPEARS UNDER THE DEVICE MANAGER, BUT WITH THE ERROR CODE 39, AND NOT UNDER MY COMP. MY COMPUTER IS AN HP DV90074 WINDOWS MEDIA CENTER EDITION.
  • gugus Jun 09, 2008
    he doesn't want work and no recognize by my computer. this problem code 10.
  • asanppiah Jul 10, 2008
    MATSHITA DVD-RAM UJ-851S ATA
  • dawsky Jul 22, 2008
    MY UJ-851S STOPPED RECOGNIZING ANY TYPE OF DISK. I GET AN ERROR CODE OF 39. THE DRIVE IS NOT DISPLAYED UNDER MY COMPUTER. I UNINSTALLED THE DRIVER AND RESTARTED THE COMPUTER. THE DRIVE REAPPEARS UNDER THE DEVICE MANAGER, BUT WITH THE ERROR CODE 39, AND NOT UNDER MY COMP. MY COMPUTER IS AN HP dv6000 WINDOWS VISTA HOME PREMIUM.
  • sweetgeo Jul 29, 2008
    When I tried to add my new Canon camera to my computer the solution disc would not read -- so I disabled it and restarted the computer -- the device driver software will not install -- Code 10 it says!
    What is this - I have not had the computer for long -- about 6 months -- is this another Vista problem??
  • rahilaaz Aug 25, 2008
    My system cannot detect the DVD ROM
  • km06 Oct 08, 2008
    problem device is Matshita DVD-RAM UJ-851S. it disappeared from 'My Computer'. does not autoplay either. tried to update driver in Device Manager but came up with Code 39 and said that i already had the updated drivers for this device.
    i have an HP Pavilion dv2000 laptop running on Vista.
  • mersparks Oct 22, 2008
    This disc drive has worked without a problem since I have had the computer now after I installed iTunes when I put in a disc it says--- Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 10.
  • jarodbrother Nov 08, 2008
    What can I say that hasnt been said. I cant watch dvd, my dvd drive is not showing on my computer yada yada yada. what the hell man?
  • Anonymous Dec 05, 2008
    same......
  • Educarretero Jan 19, 2009
    I have exactly the same problem. How can i fix it?
  • chandanraj Jan 30, 2009
    CAN ANY ONE SEND ME THE INTEX TV TUNER WITH FM DRIVER  TO MY MAIL YATHIRAJMECH@GMAIL.COM
I used my all chance to change dvd region. now is zeo (0)chance to change dvd region.
how i can reset this value help me
thanks
Posted on Sep 29, 2008
  • 4 Answers
2 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: matshita dvd-ram uj-851s ata device vista
Foolw the guide below, this will edit the registry, making the device visible and useful again.....
Windows Vista
1. Click Start
and then click All Programs.
2. Click Accessories, and then click Run.
3. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
4. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5.
6. In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
7. On the Edit menu, click Delete.
8. When you are prompted to confirm the deletion, click Yes.
9. In the right pane, click LowerFilters.
10. On the Edit menu, click Delete.
11. When you are prompted to confirm the deletion, click Yes.
12. Exit Registry Editor.
13. Restart the computer.
Posted on Jan 05, 2010
I new new software. My DVD runs on XP and I have 8.1
A DVD drive should operate no matter what the OS is - check first that the BIOS sees it and after that, in Windows, that it's being recognised in Device Manager. If it's not showing there, then uninstall the ATA controller, reboot and see if it works. There may be several controllers but if you uninstall all, Windows will detect them on reboot and, hopefully, it will also detect the drive.
I don't know if you did a clean install of 8.1 but if you 'upgraded' over XP the problem could be there. A clean install is always the best option
Apr 14, 2015 | Televison & Video
K no me funciona
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if your computer came with a motherboard disc the drivers could be on it if you don
Aug 18, 2011 | MSI Theater 550PRO (THEATER550PRO) Video...
The soft can not a pear just windows black
if you mean that you cant a screen to appear on your computer
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause a computer to shutdown
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
and you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang also uninstall some unnecessary programs and run the chkdsk utitlity
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
you should have no input while the chkdsk utility is I progress any input might damage your computer
then defragment your hard drive
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
download and run a registry cleaner cc cleaner is 100%free
http://download.cnet.com/ccleaner/
if you need any more help with this post a reply
hope this helps you
Aug 14, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Download needed RAM-OS missing
if this is whats happening to your computer otherwise i cant imagine ((download needed RAM))
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Feb 04, 2011 | VeriFone SC 5000 (M10843K31US1)
The CD won't read in any of my computers- can I download the drivers?
i think deleting the upper filters and lowers filters will resolve your problem.
Follow these steps :
dows XP loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Control Panel.
  2. Click System and Maintenance, and then click System,
  3. On the Hardware tab, click Device Manager. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
  5. When you are prompted to confirm that you want to remove the device, click OK.
  6. Restart the computer.
After the computer restarts, the drivers will be automatically installed.
See if reinstalling the drivers fixed the problem. loadTOCNode(3, 'moreinformation'); Now try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem.
Windows Vista loadTOCNode(3, 'moreinformation');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, and then click Control Panel.
  2. Click System and Maintenance, click System, and then click Device Manager.
    Note If Control Panel is in Classic View, double-click System, and then click Device Manager.
    Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  3. In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
  4. When you are prompted to confirm that you want to remove the device, click OK.
  5. Restart the computer.
Windows 7 loadTOCNode(3, 'moreinformation');
  2. Click System and Security, click System, and then click Device Manager.
Mar 07, 2010 | Vantec NBV-100U USB External Video Adapter
Matshita dvd-ram uj-851s ata device vista
Windows Vista
1. Click Start
5.
Oct 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Have a HP 9205 Pavilian( Vista)& Mashita UJ-851S will not regconize blank DVD to make recovery disk.Can anyone help??
Try to do so from Nero(ver. 8 & above) burning software and as a second thought why don't you try to do so on a CD, if it's space suffices.......sodeep
May 08, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
here's the fix
http://msbin.com/kb/entry/53/
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
Note If this data type is missing, go to Method 2.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
Dec 24, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
ERROR CODE 39
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 22, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
6,121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
