Question about Dometic 57915531 Air Conditioner
My Trailer AC doesnt cool below 75 degrees. I feel no differnce between the coldest setting on AC than on the Fan cycle. I cannot hear the cooling system kick on at all.
    Scholar:
  • 80 Answers
It should read 24v not 12v!!!!! Check your sub base on the t-stat. Voltmeter set on volts, touch R to C and get 24 volts if no common to the C then touch R to G which is the Indoor Fan Motor! If the Indoor fan is blowing air out the vents you are getting power to and through the transformer. AS stated check all wire connections and if good the problem is a faulty Contact Relay out side at the Condenser Unit! Check the low voltage wires comeing into it for 24v if it has it when the T-Stat is set to call for cooling then your contactor is bad!
Posted on Aug 22, 2010
    Problem Solver:
  • 5 Answers
If you don't here the compressor kick in after about 3 min then the thermastat is not telling the compressor to com on, or the control board is not telling the compressor to come on. The power can be traced from thermastat to the control board and will have a 12volt feed on the yellow wire at the control board with compressor mode on. From there it is 120volts the control board has a relay that turns on the compressor. the compressor capasiter can cause the compressor not to come on, normally it will have burnt wiring.
Posted on Aug 04, 2010
Hi, I have a Daikin Model FTXS35D with RXS 35D 3VNB outdoor unit. Until this year it was excellent, now does not cool as before. Have cleaned filters etc. Could it be a sensor problem. When I...
Your unit should cool 15 to 20 degrees. 75 return air temp should be below 60 degree supply air temp. If you are not in this range you likely have a refrigerant problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 14, 2017 | Cfm Daikin R410a Split System Air...
Wont get cool, can you refill?
Does AC turn on at all? if yes, remove front cover, do coils get cool at all? if no, thermostat may be bad telling unti that the desired temp reached is satified.. or.. you have the desired temp too low, if you have it set for 75 degrees, and it is 72 in your house, the fan will run and no cool air will be present.
Jul 07, 2010 | Kenmore 75085 Air Conditioner
I have an old Kenmore window unit that looks like a 72055 (control panel on top left). Although I have it set at 90 degrees and the room temperature is 75, the fan cycles on and off. How can I set it so...
most have a 'continious mode' that operates the air moving fan whenever the unit is on, or a 'cycling mode' that operates from a temp sensor usually near the input over the evaporator coil.
Look for the instruction for setting the mode you want.
I suspect the unit compressor is not starting and it just keeps retrying when the overload switch cools off from the previous attempt to start.
Jun 09, 2010 | Heating & Cooling
Air conditioner wont cool below 75 degrees
Hi, Does thermostat on a/c goes lower than 75? put hands close to air coming from a/c is it cold, like 50, if it's cold like 50, maybe you a/c are to small for space, check a/c b.t.u's ( british thermal units) how many b.t.u's is your a/c , there are a chart, for size of room and how many b.t.u's you'll need to cool space (room), or possible if air coming from a/c are 75, your compressor could be short cycling, it hard to tell when fans are working, listen carefully to hear if compressor makes clicking sound, place thermometer close to a/c vent and let me know temp, maybe there's freon leak. let me know temp of air coming out from a/c, then i could tell you exactly what's problem. good luck.
Aug 11, 2009 | Sunpentown WA-1230E Air Conditioner
Our thermostat is set at hold with the fan on auto. The house and cool temp is set at 75 degrees, yet the fan will stay on CONTINUOUSLY unless I manually take down the temperature OR the outside temp falls...
it is ok to run your fan continously. constant air filtering as long as it pauses before a/c cycles on. will not use any more electricity than a toaster. is there a fan programing feature on t-stat. if so you will need to turn programing to fan off
Jul 30, 2009 | Amana Heating & Cooling
2001 bmw 325i AC blows warm
PROB NEEDS 2 JUST BE RECHARGED. BUT STAY AWAY FROM THE DEALER. IT IS ALWAYS 3 TIMES MORE THAN A PRIVATE SHOP
Mar 30, 2009 | 2001 BMW 325
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Dometic 57915531 Air Conditioner Logo
145 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
