Question about Sport & Outdoor - Others
Old Penn 209 level wind not turning but spool works is there a part missing ??
There are many small parts within the reel itself and something may have gotten dislodged or someone may have taken it apart and not put it back together properly. There are exploded parts diagrams available at www.pennreels.com to assist you, but they can be very difficult to read. If you take your reel apart, be VERY VERY careful not to lose anything, especially a very small spring that holds the ratchet lock (dog) in place.
Posted on Sep 09, 2010
Penn 4000 Battle. How do I change the direction of the spool?
Reel only retrieves in one direction. If you turn the anti- reverse button off(lever under spool)You are able to retrieve in reverse.
May 18, 2017 | Fishing
Film-advance level not working
Nice little rangefinder, but it's 30 years old. If you can wind the advance and the film is not moving you have a big problem. They are really not repairable, you can find them pretty cheap, but remember they are 30 years old.
Jun 20, 2015 | Minolta hi-matic af2
Starter cord
remove top starter assy. cut grip from old rope ease rope into spool,
when slack remove center screw and carefully pull out spool, tie knot in rope and thread into spool, wind rope [make sure correct size rope]
around spool until full,carefully turn spool into spring 1 turn then replace screw. put rope into notch on spool and wind up 3-6 turns,
replace grip
May 19, 2012 | Mantis 2-Cycle Tiller
Rope broke
Starter rope is sold at home centers like Lowes and Homedepot. It is important to buy the same thickness of rope so that an ample amount will fit into rewind spool(starter rope is sold by size from 3.5 to 6.5) . Remove the starter cover /fan cover if the starter is riveted to fan cover (or just remove the pull rewind if bolted on). With cover removed, notice how the rope enters thru bushing and ties onto spool. Visualize in which direction the spool turns when you pull the rope. This is the direction that you will be winding the spool. Fish out the old rope and wind the spool in the direction mentioned above. The spool will get tighter as you wind. When the spool will not wind another turn, back-off one turn and align hole in spool to bushing on cover. Insert rope thru bushing into hole and tie knot (any knot that will not obstruct motor parts). At this point allow the rewind to take-in the rope to stop at handle. Test your work. The rope will break if you try to start the washer under load. Press trigger on wand to release pressure. Also the rope is stressed when the operator has a very long strong arm and pulls out the rope to bottom out at the knot. Good luck with your repair
Aug 04, 2011 | Briggs & Stratton 3000 PSI Pressure Washer
Broken pull rope of Mantis Tiller
Remove the starter assembly from the side of the engine. Remove the balance of the old cord from the spool and purchase about 1-meter of replacement cord from a saw shop (it should be nylon, not cotton). Insert the new cord into the center slot/hole in the spool, melt the end, and tie an overhand knot. Wind the cord around the spool several turns in the same direction as the old cord, then pull on the cord to wind the return spring inside the spool. Wedge the spool to prevent rewinding, then continue to wind the cord until about 8-10 inches are left. Feed the cord end through the cord port and into the handle. Melt the cord end, then tie an overhand knot and pull the knot back into the cavity in the handle. Remove the spool wedge and test the pull of the cord--it should pull out smoothly and return fully without slack. Hope this helps!
Dec 11, 2010 | Garden
The Drag on my 750ss does not work what could be the problem?
This happens after you screw the drag too tight so that the plastic washer under the spool is pressed out. The fix is simple: cut excess of that washer and tighten properly.
May 30, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Sport & Outdoor - Others Logo
158 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
