Question about Kenmore 46462 Front Load Washer
During the spin cycle, it makes a hideous, loud, rattling noise. Sounds like something has 1. come loose behind the barrel, 2. a bearing going out (do they have bearings?), or 3. a button or coin has gotten out of the barrel and into some mechanism...help!
    Scholar:
  • 32 Answers
If it sounds like a coin is rattling, chances are there is. Getting it out is not an easy feat. It requires pulling the drum out to get to the inside of the tub. Time may solve this problem as there is a reservoir at the water pump to catch coins and debris. You can access this by pulling the bottom panel off, locating the pump, and removing the rubber tube from pump and dumping contents.
I don't think I would suggest pulling the tub out with no experience for two reasons:
1. There is a rubber booth attached to the front door and the rub. Removing is easy. Putting back on is next to impossible by hand. 2. The tub is suspended by large springs. The tub is weighted by concrete and is extremely heavy. Removing it can cause injury if you are unfamiliar. Removing the springs can also be dangerous.
As for the the bearing noise. These units don't have a traditional transmission. The mother does the direction shifting. There is a bearing case, sometimes called the transmission, in this case, which is surprisingly easier to repair than getting the coin out.
Pull the screws off the back panel and remove cover. You will see a large wheel with a belt around it which also goes around a spindle on the motor at the bottom. Remove the belt simply by turning the wheel by and and slowly pushing the belt off, towards you, as you turn. Inspect the belt for wear or cracks. If needed, replace it.
Remove the wheel from the spindle and you will find a bearing or gear case. Simply remove and replace that case. You can order the part online at www.searspartsdirect.com. You will need the model number of the unit located on the back panel you removed. You may also order by calling: 1-800-252-1698.
Posted on Aug 02, 2010
My Whirlpool WTW6400Sw3 is making the loud noise during the spin cycle. There is no water leaking anywhere. I can freely spin the inner basket without any grinding noise or any other noises. Do I need
stator ? maybe? did u check for a foreign object in between the drum and barrel? sometimes a pc of something can get lodged and cause loud noises
Feb 11, 2015 | Whirlpool Washing Machines
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
Loud Clicking rattle during spin
you may have something stuck in the pump
pull hoses off pump and see if there is anything stuck in it
Jun 13, 2009 | Admiral AW22 Top Load Washer
Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
May 20, 2008 | Amana NAV2335A Top Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 46462 Front Load Washer Logo
119 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
