Question about RELIANCE ELECTRIC WATER HEATER
Top thermostat reset keeps kicjing out
Top thermostat reset keeps kickng out -- why? This generaaly happens when a load is applid such as so-
meones shower or running the dishwasher.
  • 349 Answers
Thermostat is probally going bad if it keep's tripping out. May need to replace it.
Posted on Aug 04, 2010
The water heater (Reliance Elec 501) does not turn on, This happened on the same day that our whole apartment lost power due to tripped main switch.n I reset main but water heater does not respond,...
Two-element water heater is 240Volts.
No hot water means: ECO reset button tripped, upper element bad, upper thermostat bad, or 240Volts is not reaching water heater.
Circuit breaker can be delivering power on one leg of the 240V circuit, so water heater appears to have electricity but is only receiving 120V.
Test for 240volts across top two screws on upper thermostat.
Look for loose wires and burned connections.
Push in reset button real hard.
Replace both upper and lower thermostats.
Remove wires and test upper element for continuity.
Open following links for do-it-yourself troubleshoot walk-thru:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Aug 21, 2011 | RELIANCE ELECTRIC WATER HEATER
I keep having to reset the red button on the top thermostat!! does that mean the thermostat is going out should i change both or just top one?
You can replace the upper thermostat but usually when this occurs a couple of things may be at play. You may have a small leak in the water heater, especially if over 6 years old. Or you may have a bad element. (I have seen them actually split open when removed). You can reset the top thermostat and make sure the covers and insulation are in place (after checking around both thermostats for any leaks with power off of course.) and wait for the lower element to kick on, if the reset trips after the lower element comes on then probably the element. I usually take an amp reading with a snap around ammeter (about 12 amps draw when operating correctly) only one element operates at a time. Oddly enough, I have never had to replace an element on a single element water heater, only the duals. One last thought, if the tank is run completely out of hot water it can cause tripping as well such as multiple loads of laundry etc since it is operated by a thermo disk. Hope this helps.
Feb 16, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Reliance 501 model # 5 30 2srs4. I had to reset the unit after waking up to cold water. The water heated up in no time at all but the water was super hot. So hot it triped the reset button again....
No, the top thermostat will always heat first and then it should dwitch the power to the bottom one after the top of the tank heats...this is to get you hot water faster...
The top thermostat is bad and is not shutting off or switching....
Replace the top thermostat/reset combination and you''l be good!!
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 03, 2011 | Reliance & Lowboy& Electric Water Heater
Have sta kleen 805 , have power,240 v no hot water
If I understand correctly, your water heater circuit tested for 240 Volts.
1) If circuit has power on one leg of the 240V circuit, water heater can appear to have electricity, but won't turn on since 240V needs both legs to complete the 240V circuit. Solution: test for 240 across top two screws on upper thermostat.
2) ECO reset button tripped on upper thermostat. Solution, push in reset button. If reset will not reset, then replace upper thermostat. I usually replace both upper and lower thermostats at same time: cost $28. Buy parts from home center or hardware store. Be sure to put factory-insulation and covers back so thermostat is not exposed to cooler outside temperatures, that cause hotter water than set point.
3) If ECO reset button keeps tripping, then keep resetting until you can test water heater parts. Spend 30 minutes and do complete troubleshoot on tank.
Buy cheap multi-meter from home center. When test calls for checking voltage, rotate dial to 240-250-277 VAC. When test calls for checking continuity or elements, rotate dial to Ohms (upside down horseshoe is ohms).
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 29, 2010 | RELIANCE ELECTRIC WATER HEATER
Hello, i have a reliance 606 im having a problem that the reset button, it keep on tripping. when i reset it last like 2 days then it trips again. i have changed the upper thermostat and element and it...
It sounds like you have things pretty well covered. I would change reset and if it continues to trip breaker I would check wiring very carefully where it enters top of water heater. Check for any nicks or bare spots on wiring insulation. Other than that about all I can think of is to change breaker. Sometimes they do get weak and trip to easily. Hope this helps. Thanks
Nov 10, 2010 | RELIANCE ELECTRIC WATER HEATER
We seem to have no hot water about once a week and its not from excessive usage. The reset button on the top element of our twin heating unit trips off every couple of days. I reset the push button and it...
It sounds thermostat failure. It intermittently does not open or the overlimit is getting weak. replace your thermostats and this will fix your problem.
Oct 07, 2010 | Rheem Water Heaters
Reset button keeps popping. Have reset this 3 times now and it happens at night when no one is using water. This is a model 502 heater with dual elements.
The problem I have encountered in this is the thermostat is going bad and tripping out. Inspect the ends of the elements and make sure ther eare no black ends on the wires showing elements may be shorting out causing thermostat to trip. More than likely change the thermostat out and you should be good to go.
They are not to exspensive and local hardware stores carry them.
Aug 15, 2010 | Reliance & 50gal Electric Water Heater
Lose of hot water at times
If you keep kicking the reset you have a thermostat that is bad...it could be either the top or the bottom one...but you will have the check and see if it is switching to the bottom element or not...if it does switch to the bottom it is the bottom t-stat bad, if not then the top one is bad...
heatman101
Apr 28, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water, Rheem Model RR612T, Electric Hot Water Heater, 60 g
If you don't have current, 0v from terminal to terminal, then you don't have voltage to the elements. Replace the thermostat but check that you have 220v to the thermostat. It is possible that your breakers to the unit are either bad or tripped.
Apr 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Top thermostat reset button kicks out
The top button is connected to the top heater element  which is likely shorting out. Drain the tank below the element that the thermostat is attached to. Remove and replace the element
Jan 24, 2009 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
83 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
