Question about Haier GDE700AW Electric Dryer
My dryer keeps reading E2 and won't start - Haier GDE700AW Electric Dryer
    President:
  • 3,773 Answers
Check breaker and wall plug for 230v.
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 02, 2010
Maytag epic error code f01
Maytag Epic Gas Dryer
This error code below would be indicated when attempting to start a drying cycle, or after activating the diagnostic test mode.
E1 - flashes if the thermistor is open.
The machine control electronics monitors the exhaust temperture using the thermistor, and cycles the heater relay on and off to maintain desired temperature.
Begin with an empty dryer and a clean lint screen.
  1. Plug in dryer or reconnect power.
  2. Set the following configuration:
Door - must be firmly closed Press CONTROL ON Press CYCLE END SIGNAL (Loud) Press HOLD TO START
3.
If after 60 seconds, E1 or E2 flashes in the display and the dryer shuts off, the thermistor or wire harness is either shorted or open.
  • Unplug dryer or disconnect power
  • Check wire connection at the machine control electronics and thermistor.
  • If wire connections are good, remove the two wires from the thermistor and replace the thermistor.
  • Plug in dryer or reconnect power
NOTE: All thermistor resistance measurements must be made while dryer is unplugged or disconnected from power.
Thermistor resistance: 10 Celsius ----- 19-22 kOhm
16 C ------------ 15-17 kOhm
21 C ------------- 11.5-13.5 kOhm
27 C ------------- 8.5-10.5 kOhm
32 C ------------- 6.8-8.8 kOhm
38 C ------------- 5-7 kOhm
If E1 or E2 doesn't flash in the display, the connections to the thermistor are good. Therefore, check exhaust temperature value at any or all of the temperature levels.
Hold a glass bulb thermometer capable of reading from 32 to 82 Celsius (90-180 F) in the center of the exhaust outlet.
Table below shows correct exhaust temperatures:
24385279-wycorcio5u0xxoh2plbhrodj-5-0.jpg 24385279-wycorcio5u0xxoh2plbhrodj-5-2.jpg Dado
May 10, 2014 | AEG Dryers
Hi I have a Ranco etc unit that wwaas put in my walk-in 3 months ago. Tonight the walkin started heating-up and is now at 55 degrees. The setting is reading E2. I have tried to re program but it keeps...
I believe the error code says that the brains have failed. I dont have the installation instructions with me but look it up on the RANCO web site and youll get the answer. Hope this helps good luck.
Aug 18, 2013 | Washing Machines
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
Code E1
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer stops and flashes E2 failure
Try unpluging your dry for about 5 minutes. Sometimes it just needs to reset itself.
Jan 31, 2009 | Kenmore Dryers
I have a Whirlpool Duet Dryer. I keep getting an E2 code. What does that mean?
Not sure but you can go to Google and type in "E2 whirlpool duet dryer" and it should tell you what the code means
Jan 25, 2009 | Dryers
Haier GDE700AW Electric Dryer Logo
139 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
