Question about Jandy Series Cl460 Filter Cartridge, 115 Sq. Ft
One year old Jandy CL460 unit. Within the last month two filter manifolds have cracked causing fouling of the caretaker system. The filters are cleaned often and looked clean when the cracked manifold was removed. Called Jandy and the tech had no solution.
  • 4,323 Answers
Hi
The Filter manifolds have cracked as they can only bear a maximum operating pressure of 50 PSI. After which they can crack or break, and may even cause the lid to blow off. You'll need to keep the water pressure low, check for Coupler also the O-ring around the filter.
Please check page #8 in this manual for details---
Jandy CL series Unit
Howevr, if there was no pressure issue then get them replaced as they are under warranty period. Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Aug 02, 2010
Jandy CL580 low pressure
yes try JB welding or replace it also clean filters that is what cracked it too much pressure
Mar 30, 2013 | Jandy Pool & Spa
How to stop leaks
clean seal coat seal with filter lube then put together tighten all the way so the copper nuts touch
Dec 08, 2012 | Jandy Series Cl460 Filter Cartridge, 115...
DE getting into the pool
The grids are the first place to look. You also want to check the manifold for cracks they will usually show up on the underside. Also the air bleed sock on the top of the manifold. Lastly check the grid spreader on the bottom to be sure it is flat and not warped. The grids are the first place to look though and be sure you hose them off well and check for broken frames inside them.
May 21, 2010 | Pool & Spa
Jandt filter leak
it depends, if it's leaking due to a crack on a structural part of the filter such as the tank itself, then yes, the entire tank will need replaced.
Feb 18, 2010 | Jandy PUMP SHAFT SEAL - FITS PUMPS
HOW TO GET INLEET VALVES SET PROPERLY WITH VAC
Here is a copy of the Jandy Users Manual for the model of pool filter that you own. It has a diagram of all the working parts of the filter and should have all of the information that you need. Please let me know if this does not answer your question.
http://www.backyardcitypools.com/images/jandy/CL-series-manual.pdf
Sep 17, 2009 | Jandy Series Cl460 Filter Cartridge, 115...
Jandy Lite 2 LG250N- Heat Exchanger cracked over winter
Yes I just had the same problem, the guy that I bought the house from told me to drain the pump and the filter,etc. But failed to mention there is three brass plugs on the side of the unit, so the heat exchanger cracked, but i took it to a general welding shop and they welded the crack up so that saved me a bunch of money That is all you have to do
May 16, 2009 | Jandy Laars Lite2 Lg 250,000 Btu Heater
Jandy Series Cl460 Filter Cartridge, 115 Sq. Ft Logo
719 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
