Question about Cameras
Master Software 2 help!
I have Windows XP Professional with Service Pack 2. Whenever I try to install the Olympus Master 2 software, I get this following error message from Setup:
"Installation operation failed" (00001618)
Have used Olympus Master in the past on this computer but it now fails to open, even though it tells me its installed. Error report says to download latest Quicktime, but it doesn't help.
  • CityHunter22 May 07, 2008
    Same problem here. I haven't tried updating my quicktime, but I've disabled Norton 360 and that doesn't work either.
Ditto. Installing on XP w/SP1. Plenty of hard drive space. Pentium 4 w/2GB RAM. Tried different drives. Tried copying CD-ROM to hard drive to verify it was reading of the CD ok. No problem copying but still failing on installation. I also tried by-passing the initial Olympus menu and launching the .msi directly, but that fails in the same way. I haven't found anything on the Olympus website about this, but note their website generates tons of Javascript errors which is not encouraging with respect to Olympus's attention to quality. (This is my first and probably last Olympus.)
Tried pulling the XD media and reading it on the computer but my computer wanted to format the thing (never seen that with SD or Compact Flash, what gives?) so that was a no for the moment.
Finally, I went to the files that I had copied from the CD to my hard drive and double-clicked the OM2_Pack_Framework_2_0_4.cab file found in the OLYMPUS\OLYMPUS Master 2 directory. That contains a bunch of .cab files, that I extracted to another directory. In there, I found a application.cab, which I then extracted to yet another directory. In there, I found OLYMPUS Master.exe. That ran fine when I double clicked on it, but I still had the problem of not being able to read the XD directly, so I hooked the USB up to the camera with the XD back in the camera and was able to transfer the images in that manner.
Posted on Jun 28, 2008
I AM HAVING WINDOWS XP WITH SERVICE PACK 3 BUT THIS COPY OF WINDOWS DOES NOT PAS FROM GENUINe windows validation what should i do? plz help me because notification is coming that you may be a victim of...
I understand. Microsoft has cracked down on tracking software that are installed in computers by requiring a validationg of your install operating software.
Since the XP operating system was installed on the computer when you purchased the system. Who ever sold you the computer must provide the CD key for your XP software. This CD key is five groups of numbers and letters you must enter to send to Microsoft to validtae your XP software.
Hope this information will give you what you need to validate your XP software.
Good Luck
Sep 13, 2011 | Microsoft Windows XP Professional With...
Tip
Using Scanrouter Professional on Windows XP SP2 or Vista
Scan Router Professional software will not operate on Windows Vista computers at this time.  It can install on Windows Server 2003.
There have been issues getting Scan Router software to work with Windows XP with Service Pack 2 or higher.  While you might be able to install the software but some features may not work.
The best solution for now to get around this is to install an ftp server on your computer or server.   servu.com has a free one that you can use.
Desktop Binder software will work with Windows XP Service Pack 2 as well as Vista.  Make sure that Windows Firewall is turned off before using it.  If your behind a router with a firewall on it, you shouldn't have it enabled.
on Sep 13, 2008 | Ricoh Aficio 1035 Copier
Serial number of service pack 2
Here try this one, This is for windows xp service pack 2
JHJBY-RFR88-8F8G4-TPG8M-4Q67Y.
Hope it helps, please rate my solution Thanks.
Jun 30, 2011 | Microsoft Office XP Professional + Service...
Problem in office 2007 setup
HI Deb,
You will need to update windows to service pack3 first. Then once completed click "start" and open "control panel" and then "Add Remove programs-software" Scroll through list of installed software and identify all and only the office related components "select" each component individually then click "remove/uninstall" Remove all previous installed office components, starting with the smallest sized file to the largest, once completed restart your machine and try the office install disk again. See below for service pack three download info and links:
Download the service pack manually You can use Windows Update or the Microsoft Download Center to obtain Windows XP SP3 online. Check for updates on Windows Update loadTOCNode(4, 'moreinformation'); To check for updates on Windows Update, follow these steps:
  1. Visit the following Microsoft Web site: http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com)
  2. Click Express (Recommended).
  3. If your computer is up to date, Windows XP SP3 will be one of the updates that is automatically selected. Click Install. If your computer is not up to date, Windows Update will offer some other updates that you have to install first. Install those, and then repeat steps 1 and 2 to obtain Windows XP SP3.
  4. For Windows XP SP3, review and accept the Microsoft Software License Terms.
Windows XP SP3 will be downloaded to your computer, and the Windows XP Service Pack 3 Setup Wizard will help you install it.
Download the latest Windows XP service pack from the Microsoft Download CenterIf you have problems obtaining the service pack from Windows Update, you can download the stand-alone update package from the Download Center. This page will say that this installation package is intended for IT professionals and developers. However, you can safely download this file. The following file is available for download from the Microsoft Download Center:
Download the Windows XP Service Pack 3 package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4)
Jan 23, 2009 | Microsoft Office Professional 2007 Full...
Have upgraded to Windows XP. Do I require new Camedia software as Camedia Master 2.0 version that I have with my Olympus C-3030 Zoom will not install. Thanks - Jamie Gardner
The camera is a standard connect camera and what we recommend for XP and Vista users is to look into purchasing a smartmedia card reader that connects to USB port so that you are able to transfer images using the reader as opposed to connecting camera to PC. The camera connection is not XP or Vista compliant.
Olympus Master 2 software download snippet
To learn about the new and free version of Olympus Master 2 software go to: http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master 2.x, 4.x, Olympus Master 1.1 and is XP and Vista compatible.
Aug 25, 2008 | Olympus Cameras
Comment by Jerra: I got it to load for me when it asks you to connect to camera automatically, delete the tick. it took awhile to download from the disc.
Apr 01, 2008 | Olympus FE-220 Digital Camera
Hello
the black screen at windows startup implies that u have a probleme with ur software package(service pack 2)
so get a fresh copy of the softwares u have mentioned
then 1st install windows serice pack 2 from the bootable disk
after that when windows starts install ms office professional.
below is the link to download windows xp sp2 and ms office2007 professional(better u use opera 9.25 version or higher version for download)
For windows xp sp 2-
http://www.mininova.org/get/1178630
For ms office proffesional-
http://dl.torrentreactor.net/download.php?id=1406943&name=MS+Office+2007+Professional+Plus+%2B+Expression+Web
after downloading xp sp2 ,burn it on disc using nero and then install from cd
Feb 27, 2008 | Microsoft Office XP Professional + Service...
Windows xp error
so you can run a windows cd but cant run other apps?
Nov 12, 2007 | Microsoft Windows XP Professional With...
Cameras Logo
381 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
