Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel mix What is the proper fuel mix for the model 110?
  • 23 Answers
Quick check with mfg (DAGS mcculloch) yields: 40:1 with their 2-stroke oil and 87 octane.
I've run one (with 14" bar) for years on same 50:1 mix I use in other saws with no problems- synthetic oil and regular gas. One of these saws is now 30 yrs.old. And ... no smoke-cloud, nor port/muffler mung.
With new saw, you might want to use more oil for first few hours. Just remember that doing so leans the fuel mixture.
Posted on Aug 18, 2010
I have an Evinrude 7.5hp outboard motor.Mod# 8RC1A SN# 0178194. What Year of manufd? How to mix fuel & what octane fuel to use & what oil to use? Help me go fishing, thanks.
91 octane rating ( no e-mix fuels ) and proper outboard oil ( not normal engine oil)
outboard oil has a property that allows the oil residue to stick to the metal bits and helps prevent rust
e-mix fuels absorb moisture and and rusts out steel tanks , destroys rubber components and corrodes aluminium components
the model you have is not listed on any 7.5 hp engine from 1950 to 1958
model number starts at 4434 to 7512 to 7525 in 1958
for a better answer , talk with an evinrude service center who should have a chart listing your motor
units with oil injection are 50: 1 ratio and others are 6 gallons to 1 pint of oil which is around 45:1
I would seek advice from an evinrude service center for the correct fuel to oil ratio for your engine
to mix the fuel , put the oil in first then the flow from the bowser will effectively mix it up to start with
then fit the cap on the tank and shake it up yourself
Apr 20, 2017 | Boating
Ford transit 2.2 57 plate 110 t260 has just started to misfire and black smoke what could it be wrong please help
Several possibilities:
1. you have carbon build up on one or more valves preventing them from completely closing which would cause misfires and black smoke
2. worn rings allowing too much oil to remain in the cylinders
3. sticky choke preventing sufficient air for proper fuel mix causing misfires and incomplete combustion (black smoke)
4. dirty air intake filter
May 03, 2015 | Ford Cars & Trucks
I used fuel from old chainsaws sitting in garage and used it on my Echo CS-330T. I barley got it and it was basically new with a few hours of use. I guess the fuel was old and the gas was probably not...
Use echo 2 stroke oil Do not use ethanol fuel, use a premium fuel and mix with the oil. Empty all the old fuel out of the saw, Fill with fresh fuel. Should solve the problem
Oct 05, 2013 | Garden
I do not know the proper gas oil mix ratio can you please help?
As you do not say what make and model we are talking about, i would be quite happy to run any machine on a 25-1 fuel oil mix, with a suitable two stroke oil.
Apr 16, 2011 | Garden
My kawasaki klx110 is not turnin on does this bike need mixed gas
hi, this bike has a four stroke engine and requires petrol only, (not mixed fuel)
Jan 18, 2011 | 2005 kawasaki KLX 110
Hello,I have Mac 110 model#600016c It`s in need of a little TLC The saw is about 25yrs.old and has never hadany work done on it.I need to know what the spark plug gap should be and what the gas/oil mix...
Spark plug gap should be: 0.020" and the fuel to oil ratio is 40:1. Be sure to use fresh fuel and a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Mix well in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel mixture for Eager ****** 2.0 CID
40:1 is the proper ratio of fuel to oil mix. Mix the fuel and oil in it's own can and be sure shake the can thoroughly just before filling the saw each time. Be sure to use a modern synthetic oil made for saw use and fresh gasoline. Hope this helps!
Jul 02, 2010 | Garden
Fuel mix ratio for 110 12'' McCullough chainsaw
The OM for my MAC 110 says 40:1 (1 gallon of premium fuel to 3.2 ounces of quality oil).
I operate it on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality oil) without a problem.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 02, 2010 | McCulloch Garden
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Oil
40:1 fuel mix ratio is good for this model. you put gas in the upper tank and 2 stroke oil in lower tank the mix pump will do the mix, if you are not sure the pump is working properly, mix 4 ounces of 2 stroke oil into 1 gallon of gasoline and put the mix in the upper tank, it reach the carburator by gravity
Nov 20, 2008 | 2005 Honda Dio
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
180 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
