Question about Samsung SIR-T451 DirecTV DTV Receiver
Samsung SIR-T451 No signal on almost all channels.
I have the same problem others have where the auto programming skips most of the stations, adds two or three but when you go to those channels, they say no signal. When you check the signal strength on the menu, there is none. I do get two channels Nick on Demand, and another Nick channel. I briefly got an MTV once but it is gone. On those channels the signal strength is the highest bar but I don't get any of the regular HDTV channels. It is hooked up to a Sony KV-36XBR400 TV. The connection is cable coaxial signal to Samsung In; Samsung out to Sony TV UHF/VHF in. I'm in Bklyn, NY so there should be signal strength all over the place for the unscrambled HDTV channels. Any suggestions?
SOURCE: Operator manual for Samsung TV Model CI-14F1TS
I can only get channels 2 through 14.
Posted on Mar 31, 2008
ginko
  • 19396 Answers
SOURCE: VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Posted on Jul 26, 2008
  • 267 Answers
SOURCE: Channel select
are you on "air" mode not "cable"
Posted on Mar 06, 2009
  • 13 Answers
SOURCE: I have had my 40 inch Samsung LCD for
I have come across that problem about 8 times in the past, only solution to your problem is to have the main board replaced.
Posted on Jun 21, 2009
  • 45984 Answers
SOURCE: Samsung 2006 hdtv. Got new hd indoor antenna, set auto program and still no channels. When I had my old tv with converter box and indoor antenna I got 8 channels. What am I doing wrong?
If the new antenna was connected correctly, it may be ng.
Posted on Jul 14, 2016
Can't get channel 29 to come up. Tv worked fine, then now it skips to the next channel.
Go to your TV settings and manually add the channel. Sometimes if TVs don't detect a signal from that station it Auto deletes that space
May 11, 2017 | Televison & Video
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
I have the box installed and on. Now what do I do to get the local stations on my TV
What box - satellite/cable/digital-to-analog converter? This tv has a digital (ATSC) tuner built in. So if you are looking for OTA channels, use antennaweb.org or tvfool.com to find out what direction to point your antenna and what antenna you need. Then connect the antenna's coax cable to your TV. Antennaweb is very conservative and assumes an outdoor antenna. tvfool.com will list several more channels and the different antennas that are needed for various distances between your location and the station transmitters.
If you are sharing one antenna between several tvs or tv and other devices, you may need an amplifier in addition to the splitter. (Unfortunately, these can get damaged by surges as well. I've lost certain channels after a lightning strike turned the amp into a filter for one part of the RF signal spectrum.)
Once you have the antenna connected and pointing in the direction of the desired station, you will need to scan for channels. If this is the first time the tv is set up, you will be prompted for menu language, the input type and then asked if you want the TV to auto-scan for channels. Otherwise, hit Menu, use the left and right arrows to get to the Channels menu option and press the + button in the center of the arrow keys. Next use the up and down arrows to set the incoming signal (if needed) - the item is labeled Cable and is a Yes/No (again press + to select item and to enter the change). Continue down to the Auto-program and let that run. You can add/remove channels from the resulting listing with the Channel Skip/Add option just below Auto-program.
I hope this helps.
Jun 21, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Weak or no signal
the actual tv was not on channel 3 and the av1 port was wrong
Jul 09, 2009 | Samsung SIR-T451 DirecTV DTV Receiver
New ariel installed on communal roof, have tried auto store, some channels now missing, samsung 23" LCD TV LE23R8
 you must run "auto program search"/"auto store" again and let the TV find the programs. then put them in order and store.
If you feel some channels are missing, try to find them manually. The auto store function sometimes skips programmes with less tolerant range, even if they are watchable in a fairly good quality. And search slowly and pay attention and go back if you feel you just skipped something. Good luck and lots of patience!
A new aerial sometimes might mean loss of some channels.
I hope it was helpful
Apr 17, 2009 | Samsung Televison & Video
How to restore factory defaults on SIR T451 settop box?
part of losing the channels is the digital transitions. some channels may come in some may not depending on the strength while this transition takes place. resatart the receiver and run the initial set-up. make sure the not to skip the zip code part
Jan 03, 2009 | Samsung SIR-T451 DirecTV DTV Receiver
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
No signal
reconnect the antenna and restart the receiver. then go into the menu and a run the initial setup. make sure you dont skip the zip code. it may take a moment to register all the channels
May 13, 2007 | Samsung SIR-T451 DirecTV DTV Receiver
Reciever won't boot
If its anything like or reciever try holding the power button for about 6 secconds and see if it does a fresh reboot.
Mar 25, 2007 | Samsung SIR-T451 DirecTV DTV Receiver
Samsung SIR-T451 DirecTV DTV Receiver Logo
101 people viewed this question
Jerry Greenberg
Jerry Greenberg
