The mouse was apparently dropped and as a result the wheel is loose and not always perform as it should. i need to take the unit apart. i am looking for a manual
  • 2,229 Answers
I don't think you will find a manual for fixing a mouse. There are screws in the bottom (may be hidden under little rubber feet). Undo the screws and pull the two halves of the mouse apart.
Posted on Aug 02, 2010
Why dosen't Gearhead tilt wheel work after I restart my computer
uninstall the driver and re install. gear head uses generic drivers that can cause unwanted and undesirable performance
Mar 06, 2014 | Gear Head Wireless Optical Tilt Wheel...
Cleaning the Microsoft Wireless Mobile Mouse 4000
I disassembled my Microsoft Wireless Mobile Mouse 4000.
You need a set of precision screwdrivers to do this.
1. Peel up the teflon pad on the bottom of the mouse with a flat head screwdriver. Leave the other (the one under your fingertips) alone.
2. That will reveal a tiny silver screw. Remove that and then lift the gray upper section up from the back, then pull it free by moving it toward the back. The clips up at the front go in a forward direction, but they are not clipped in. You could just shake it free.
3. There are 4 tiny black screws. 2 at the front and 2 at the back. Remove them.
4. Use a flathead screwdriver to pry the retainer clip from the back of the mouse. It's just held on by a couple of little nubs. Don't break it. Be gentle with this part.
5. Now, the mouse can come apart. You need to pull the bottom of it free at the back and then slide the entire bottom section back. There is a little piece of circuit board that sticks out underneath the right-click area that will get hung up on the upper shell if you try to pull it straight down. This will take a little bit of prying since it's all clipped together, but it will come loose.
That's it. I didn't take any of the inner parts apart after that. I will say that my sticky scroll wheel was scraping against the upper shell. By loosening the two screws at the front, it relieved some pressure and let it run more smoothly. I didn't actually have to take it all apart after step 2 in order to fix that issue.
Mar 08, 2012 | Microsoft Wireless Optical Notebook Mouse...
Dropped wireless mouse and wheel shifted & buttons hard to push
I had a similar problem and was able to fix it. The left mousebutton was clickable, but needed extra force.
After opening the mouse I found that at the side of the mousewheel there was notch pointing upwards, preventing free movement of the left mousebutton. I was able to rotate the ring with the notch back into horizontal position after gently pushing the housing surrounding the mouse wheel wider.
Apr 25, 2010 | Logitech Cordless Mouse
Goodmorning. My keys are sticking on my E627 and I tried to take it apart but cannot get it apart at the point of where the mouse is....Any suggestions
All keyboards are always held down my screws in the bottom of your laptop casing. Also if you recently drop liquid on your keyboard, you might want to take care of that before it becomes a bigger problem. Note: look for the screws on your case that are marked with keyboard looking symbol. This will help identify which screws you need to remove. Please get back to me with any questions.
Jan 31, 2010 | Acer eMachines 520-2890 Notebook
Mbj58 wheel mouse curser wants to go all over screen
Hi a. Have you tried another mouse and
b. Are you using a glossy or prismatic mouse mat? Try using a different one or a sheet of A4 and see if this fixes it
hope this helps Mark
Aug 22, 2009 | Logitech Wheel Mouse Optical
Drivers side rear turn signal and brake light not working
I've noticed the same problem with my 2001 Ford Exployer Sport Trac. When my girlfriend drives my truck she raises the steering column, and when I'm driving, I lower the column. I noticed when I was driving recently the left front turn signal kept flashing quickly, thought it was the bulb, but changed and still happening. Today I took apart the steering column cover and noticed the wiring for the turn signals and hazards were loose. To fix this problem I pulled the wires out of column more as to not stress the connection. So far this has fixed the problem.
Dec 14, 2008 | 2001 Ford Explorer Sport Trac
Microsoft Wireless Optical mouse 2.0 Sticky central wheel
I just took mine apart to fix same problem, works much better but not sure for how long.
Quite simple to dismantle the unit.
Take the battery cover off, remove batteries.
There is a small screw in the middle of the battery cavity, you will need a very small Phillips head screwdriver.
Gently ease the base (holding circuit board) from the top shell
The wheel unit can be gently eased out of its cradle, use the small screwdriver to pop it out, watch out for the small spring between base and wheel unit, don't lose it
You can disconnect the wheel unit from the circuit board by unhooking the small plug connector
Now defluff, then clean the wheel - I used a tiny amount of turps on a cloth, anything similar should work. If you look closely the reason the wheel won't roll smoothly is that the gel ring on the wheel is too close and rubs at the front and back of the cradle. Once grime builds up, this problem makes the wheel unusable. Roll the wheel back and forth along a clean surface once cleaned, should start rolling freely again.
I also unscrewed the top shell from the mouse buttons (all one piece, pinch the plastic pegs in the centre of the shell together to release) and cleaned the whole unit up before putting it back together
Don't forget the spring when putting the wheel unit back. When screwing the base to the top shell make sure there is no play between the two parts before you put the batteries back in, mine was a bit tricky to get tight again but worked fine second attempt
Sep 07, 2008 | Microsoft Standard Wireless Optical Mouse
Logitech Performance Laser trouble
Probably internal organ damage, most likely deceased caused by the probable drop.
Jul 12, 2008 | Logitech Cordless Mouse
Assembly of scroll wheel parts
Hi, We need more details such as what make & model your mouse is their are over 80+ different mouse's about so no one can help until full details are supplied by you. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 11, 2017 | PC Concepts EZ Scroll Wheel Mouse
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
