Question about Aiwa Audio Players & Recorders
I have a aiwa LX-D10 & the arm doesnt lower anymore just makes a funny noise can anyone help please?
    Brigadier General:
  • 3,301 Answers
Remove the bottom of the unit, and if you look you'll see that the shaft has jumped the lockdown ,, a simpler problem could be that the hold up arm if engaged
Posted on Aug 02, 2010
Testimonial: "thank you very much was a big help A1 service"
  • Dudley Peacham
    Dudley Peacham Mar 12, 2014
    I have this exact same problem too but having taken the bottom of the unit off, I do not know what to correct. Can anyone help with instructions or pictures?
My Aiwa px e860 record player arm is too heavy how do I adjust it?
If you put the maker and model number into Google you will find a service manual free for the make. That should help you sort out the problem. It's just a question of getting the weight at the other end of the arm adjusted right.
Dec 11, 2016 | Aiwa PX-E860 Turntable
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
May 01, 2015 | Aiwa Audio Players & Recorders
I have Aiwa LX-D10 the arm will not travel or rise or lower, Can you help
Does the platter on the turntable turn? You should be able to make it swing out by hand operation of turning the platter.
If you can do that it's likely that the belt to the turntable is slack and needs replacement.
Nov 12, 2014 | Audio Players & Recorders
I was listening to AIWA home stereo integrate amplifierMX-D10 n suddenly no sound
If you are hearing a very faint sound from both speakers, make sure your tape button or lever is switched off.
Apr 22, 2014 | Audio Players & Recorders
The ice maker is making a funny noise, with either the wire shutoff arm raised or lowered. It is not making any ice and the noise sounds like a croaking frog... Any help would be great. Thank...
You might have some ice stuck in the mold. Pour some hot water into the mold area with a turkey baster and see if this helps. Be sure to clean up any excess water in the mold area by soaking it up with dry paper towels. There should be no noise coming from the ice maker if it is off, so it's probable in a harvest mode.
Feb 23, 2011 | Refrigerators
Aiwa lx 70 turntable needle arm
This is not a solution but it is information. I just got one of these turntables and the platter rotates but the tonearm does not move. I took it apart after downloading the service manual and found that there are two small thin rubber belts that due to age have fallen apart and "melt" when you try to pick up the pieces. One controlled the sideways movement of the tonearm "carriage", the other controlled the lifting and lowering of the tonearm. The replacements are expensive (I think around $18 each) and in trying to pop loose a worm gear with a pulley buit into it, so that I could try a cheap rubber band out just to see if the unit would work with new bands, I broke the stiff plastic "retainer" that by its shape was designed to be pushed out of the way a bit to allow the worm gear to be removed. The service manual, by the way, had all sorts of information about how to make fine adjustments, but said nothing at all about how to replace the belts. Unless removed there was no way to put the replacement band in place over the gear/pulley combination because there was no exposed end to slip a complete band over. So I think it was a bad design, made worse by the aging of the components that made the bands melt and the plastic "keeper" brittle so that instead of flexing out the way it broke. So I'm going to recycle the components. I did not find any reviews to tell me how good a component unit this was, so before you hire a pro to try to fix this unit you need to figure out if it will be worth it to you in the long run. Anyway, good luck.
Feb 15, 2010 | Aiwa Audio Players & Recorders
What is the bar or rod called that is on the drivers side hooked to the lower controll arm and goes towards the front it has bushings in it were it connects to the lower controll arm- thoes bushings are...
The rods that connect the K-member (subframe) to the lower control arms are called "strut rods". Your local auto parts store should carry the bushings.
Dec 02, 2009 | 1997 Ford Thunderbird LX
Ipod Classic 60 GB isn't recognized by computer anymore.
download the most updated itunes and try reinstalling your it.
May 27, 2009 | Apple iPod classic MP3 Player
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
286 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
