I have a Canon MP460. I have tried 3 sets of ink cartridges MP-40 and MP41 and the printer fails to recognise the cartridges. Would you have any idea to what the problem may be? Many thanks, Sean
  • 5 Answers
The problem may be with the connecting strip ( white) between the cartridge bay and the control board. rmove the strip and clean both the connecting edges using isopropyl alcohal and soft cotton cloth. reconnect it
it will not work if somewhere it is broken, so check it also.
It may be due to the contact pins, from where the printer communicates with the cartridge. so check whether the contact pins are clean or clean with isopropyl alcohal using a soft cloth. reconnect the cartridge and off on the printer.
clean the cartridge contact area also with the same.
Posted on Oct 06, 2009
    Genius:
  • 3,587 Answers
Sure...wrong kind of cartridges, no doubt...those cartridge detect programs are quirky at best anyway
Posted on Apr 25, 2008
My Canon MP460 Printer will not recognise new ink cartridges? Do you know why? They are the correct ones!
When you say does not recognise the cartridges. What does the display and pc say? Also observe the orange and green lights and tell us what sequence they flash.
Thanks
May 30, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Pixma MP 460 doesn't recognise printer cartridge
you need a resetter for that, download on the net. i fix my problem like that because i use resetter and my printer work now..
Nov 04, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp 145 E4 problem
Dear Sir,
Error Code E4 = No ink.
Generally printer doesnt recognise refilled ink.
Try the to reset the ink catridges
by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
if you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
Apr 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Impossible to use a Canon mp 180
Hi Lui,
this is a common problem when using refilled cartridges.
You can either go into Control Panel --> Printers and Faxes
Right click on the printer and select properties, then look for a maintenance or color section
There should be a setting to ignore the cartridge levels
If this fails look at the solutions here:
http://tricks-collections.com/2008/04/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
thanks, good luck HPC
Feb 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp460 all in one printer will not recognise ink cartr
You need to check that the canon label on top of the cartridge is near to the to the two lugs, there should be only a tiny gap. The label should not be placed at the bottom near the curved lug. If it is not in the right place I think it covers the chip that talks with the printer and thus sends an error message.
Jan 25, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp460 not recognising replaced ink cartridge and cannot get rid of alarm code
hi guys,
BTW, did you refill the cartridge?. First, try to press START button (Black or Colour). Perform this procedure for each cartridge. If the problem still persist there some possibilities: cartridge error, carriage part or logic board is faulty. Then you need to replace faulty part.
Regards
Source:
Canon Inkjet Forum
Dec 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Use of High yield Cartridges in Canon Pixma 150
have u tried to remove the cartridge again, proably some contact problem
May 27, 2008 | Canon PIXMA MP150 All-In-One InkJet...
94 people viewed this question
jasbo
jasbo
