Question about Optoma PD50 50 in. HD-Ready Plasma Television
After setup there is no picture just the sound plays
Once we hooked up the tv the screen was black but the sound plays.
it says looking for signal goes blue and then black.
  • Optoma Master
  • 8,457 Answers
Tries unplug the tv and the cable box about an hour,replug both back in.The cable box,will upgraded it software and the tv will reset itself back to factory setting.Every things should work now.Not,than the tv Tuner board,it dead,that board,that take in the incommimg broscasting signal cable to the tv.
Posted on Aug 02, 2010
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
Attempting to connect the HDMI cable from the computer to the TV ( model LC320SL8) I'm not getting a signal or any sort of feedback. just a black screen. i once had the tv hooked up to my laptop a
HDMI can be flaky and does not like things to be connected while units are powered up---tv or the unit being connected.
If you hooked up with set on etc the set may not of "seen" this event and refuses to function. I know it sounds odd but I have seen this many times.
Oct 30, 2012 | Sylvania LC320SL8 Television
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
I have sound but no picture. The screen is black
can you see any any menus or the volume bar or channel indicator?
Make sure all your audio and video cables are hooked up correctly to inputs on the TV and to the same set of hookups. For example all of the VCR cables hooked into video 1 and all of the DVD cables in video 2.
Also check that you haven't hooked up the video to the tv's output. Some sets output audio and/or video for external devices such as recording setups or home theater sound systems.
Oct 17, 2009 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Give sounds, but no picture, how to reset graphics
make sure all your wireing is corectly hooked up
Oct 06, 2009 | Televison & Video
Power on tv and I get black screen with sound.
You have lost the input signal...you will have to go to Setup/Net Command and set your input to the one with signal (either a TV input or a Component input). If it is reset...the input likely switched to a non-usable input
Jul 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No visual picture
If it's a setting on the PS3 then just hook it up to another T.V. set it back to default and hook it back up to your other T.V.
May 28, 2009 | Sony Playstation 3 (PS3) Console
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
HDTV Setup
it wont hurt to run both to the set, they wont interfere with each other
Nov 28, 2007 | Televison & Video
NO VIDEO
It sounds like the video signal is being routed to a different out put. Search the menu for "Source" kinds of settings. Often you will have Vid 1 and 2 and maybe HDMI 1 &2 etc. Try what looks right and keep trying all combinations (usually less than 6). Take your time, it often takes them numerous seconds to recognize the signal. The fact you see the settings means the Video is working if it just had the signal. Also, if there is any wiring involved, check the cables and maybe swap them for known good ones if possible.
May 20, 2017 | Pyle PLDINTV7 Car DVD Player
Optoma PD50 50 in. HD-Ready Plasma Television Logo
74 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
