Question about HP mx705 17" CRT Monitor
I have a monitor svga TSSI model TS-507XM, say me that is a monitor HP MX705, is true. No turn on and make it one noise ¡tictictic! of the side fly-back
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
  • 85 Answers
SOURCE: HP mx705 17 in.CRT --Blank monitor
I assume the monitor is still plugged into the back of the system?
If so, do you get any beeps which can denote error codes for the system?  Put your ear to the monitor, any strange whinning noise?
Posted on Oct 23, 2007
banar
  • 26 Answers
SOURCE: demagnetize computer monitor
It looks more with screen resolution problem, if it is new then the best option is get it replaced.
Posted on Dec 12, 2007
  • 26 Answers
SOURCE: Flashing Green Light on mx705 monitor
If the HP has onboard video but you have an add-on video card, remove the add-on and connect the monitor to the onboard vid. If it works you have a bad add-on video card. If it doesn't or you are already running on on-board video hook the mx705 up to a compatible HP. The older PB may be TOO old to handle it or not hve the correct drivers.
Posted on Feb 25, 2008
hmerchant110
  • 7191 Answers
SOURCE: monitor picture has rotated 90 degrees to the
Hi, To correct the monitor , press CTRL+ALT+UP arrow keys together. Hope this solves the problem. Thanks.
Posted on Jul 23, 2009
Blank screen, no light indicating monitor is on, makes clicking noise when i click to turn on. It is a hp mx705.
It is either the power supply or the deflection circuit.
If you can read electronic circuits and know how to use a DVM. Check the power supply voltages and the deflection circuit for any short..
Best of luck.
www.aaatvservice.com
Mar 04, 2011 | HP Compaq FS7600 17" CRT Monitor
HP MX705 ON MY DESKTOP JUST WENT BLACK AND BLANK. THE POWER LIGHT JUST BLINKS.
a CRT monitor  just like a CRT television when it fails may still have a light on the front panel operate   you probably had a catastrophic failure  usually small electrolytic capacitors near the horizontal output transistor dry up an cause the transistor to fail  the voltage regulator may also fail in the process
Nov 07, 2009 | HP mx705 17" CRT Monitor
Menu(user mode )display is coming again and again?
While your PC is turned on, disconnect the monitor, and unplug, then plug it back in, and reconnect it back to PC..
May 14, 2009 | HP mx705 17" CRT Monitor
Hp mx 705 monitor the brightness menu appears andautomatically increases brightness to 100
Facing same issue in HP M704 from 12th Mar 08. It was working good for more than one year. Planning to contact customer support for service.
Mar 09, 2008 | HP mx705 17" CRT Monitor
Feb 25, 2008 | HP mx705 17" CRT Monitor
Demagnetize computer monitor
Dec 12, 2007 | HP mx705 17" CRT Monitor
Monitor problems
it an hardware problem i would suggest u check the display i.c of the monitor
Dec 10, 2007 | HP mx705 17" CRT Monitor
Oct 22, 2007 | HP mx705 17" CRT Monitor
Monitor goes standby after boot
Look the problem it may not your monitor it's your windows XP. Let me guess you have a VGA/Svideo card. From prior experience I can tell you that dual output Nvidia cards will default to Svideo first, and then "adjust" your windows settings to do so every time even if a VGA monitor is re-connected (HIGHLY ANNOYING). So if the last thing you see before nothing is the Windows XP boot screen, here's how to fix it. Boot to safe mode uninstall your video driver, reboot then reinstall. You can substitute a system restore for uninstalling your drivers if you can remember when the monitor was last working. This really really pissed me off when it happened to me.
Jul 09, 2007 | HP mx705 17" CRT Monitor
While it is sounding like a hardware problem. I'll throw in my 2 cents. Have you check the cables from the power to the source and from the monitor to the computer. Just make sure those aren't loose. One other thing...you mentioned you turn off the computer "afterwards" then it fixes itself. Is the fix for longer than it turns on at first? or does it stay on longer then goes out? Let me know what happens. Good Luck, Tim
Mar 14, 2007 | HP mx705 17" CRT Monitor
HP mx705 17" CRT Monitor Logo
220 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
