Question about Norelco Arcitec Electric Shaver - Gray/Black
Don't know how to remove the razors to clean
The unit seems very fragile, and everything's 'bendy' so it seems that any part can be broken easily.
I don't have a manual. So I can pop up the razor units, but cannot remove them. Tried twisting them clockwise/counterwise at the 'axle' and tried to slide them out but to no avail.
Do you have a quick method? My razors getting cruddy quickly.
  • Norelco Master
  • 1,626 Answers
It is not possible to disassemble the shaver heads to thoroughly clean them like older models. You will find a user manual at the link below
http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
You may find it necessary to replace the head. You will find it at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on Aug 06, 2010
Whats the unlocking code for my motorola rozor cell phone
I don't know the Unlock code for your Motorola Razor cellphone..Unlock code generate from network database based on IMEI number,Model,Country,Network it locked now!!
To get the unlock code visit the site Prounlocking.com here you can get the unlock code and unlock it easily
Aug 18, 2012 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Puddles on floor under freezer side coming out the front, we check the drain pan and it is dry and the tube draining to it is in position and seems to be not damaged in any way. Where is the Defrost Drain...
HI. IRECON U HAVE A DRAIN BLOCKED.DEFROST EVERYTHING FIRST.U MUST HAVE ICE INSIDE THE PANEL TOO.DIFFICULT ACCESS WITHOUT REMOVING PANEL BUT U CAN TRY A LONG BENDY COPPER TUBE .BEND IT SLIGHTLY INTO THE DRAIN HOLE AND BBBBLLLLLOOOOOOWWWWW.U MIGHT GET LUCKY.IF IT FAILS U NEED TO TRY IT WITH GAS.(COMPUTER PRESSURIZED CLEANING GAS CANISTER).GOOD LUCK ali
Jun 30, 2012 | Admiral 26 cu. ft. Side-By-Side...
Can anyone help with some advice for home razor repair?
After dropping the razor it is very difficult to know what the problem is without examining it. Based on the symptoms you describe, I would guess that the the 'drive unit' is damaged. You will find this part available at shaveroutlet.com. See link below. Scroll down the page for installation help video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Oct 26, 2011 | Braun 360° Complete 8985 Electric Shaver
HOW DO YOU CLEAN THE RAZOR
Good day!!!
if you wish or need to clean you razor you only have to do is to open the cover (unscrew) then use a paint brush to clean the your razor after that put some oil to lubricate the razor and that's it..
thanks for using fixya..
have a nice day!!!
Jun 30, 2011 | Philips Philishave Cool Skin HQ5620
I have a new ES-LA93 razor which I love but I have one question. After shaving I press the [SELECT] button to choose Clean/Dry/Charge. The process finishes and all seems fine but the CLEAN and DRY course...
If you clean the razor every day, the CLEAN and DRY lights flash repeatedly to show you that the cleaning has completed. You should be able to confirm that this is correct by NOT cleaning it one day. You should see that those lights don't flash then. I know this because I clean the razor twice a week rather than every day. On the days that I clean it, the lights flash. On the days that I don't clean it, the lights don't flash.
Nov 08, 2010 | Panasonic Health & Beauty
We have an older corning cook top and it seems to burn or stain very easily. What is the best cleaner to use without scratching the surface.
I use a razor blade scraper to remove the heaviest deposits and then scrub it clean with Bar Keeper Friend cleaner.
Aug 08, 2010 | Verona 34 in. CTG536S Gas Cooktop
I have a Norelco model 7315 razor that I purchased in October 2009. In the last five weeks, in spite of being cleaned regularly, it developed a very unpleasant must odor that seems to emanate from the body...
It is very unlikely that the smell is coming from the body of the shaver. Have you completely removed the heads and thoroughly cleaned them individually with alcohol or shaver cleaner? If you are simply rinsing the blades under the faucet and have not removed them and thoroughly cleaned them, this is almost certainly the problem. The smell is decomposing hair and oils from your skin.
You may want to consider using a shaver cleaning product like the ones linked below from shaveroutlet.com
http://shaveroutlet.com/norelco-al80-razor-lubricant-spray-p-255.html
http://shaveroutlet.com/shaver-accessories/eltron/eltron-parks-shaver-cleaner-p-737.html
Jun 29, 2010 | Norelco Rechargeable Cordless Men's Razor...
My antenna no longer seems to work, is it an easy fix?
The antenna connection on the Quest is very fragile and is easily broken internally. Fit an external antenna and this should fix your problem.
Jun 16, 2010 | Garmin Quest GPS Receiver
Charger seems not to work and indicator lights on
The chargers are pretty fragile - I've seen several dead ones. If the light doesn't go on when you plug it in you pretty well need a new one.
Feb 20, 2010 | Razor E100 Electric Scooter
Phone wont ring
there are 2 speakers, 1 for ring tone, 1 for music, ring tone speaker is fragile easily broken if phone is dropped, have to replace the 2 as 1 unit
Sep 18, 2009 | Sony Ericsson W890i Cellular Phone
Norelco Arcitec Electric Shaver - Gray/Black Logo
143 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
