Question about Poulan Garden
Hard to start
Was always hard to start can sometimes get it to run by priming thru carb will run and idle
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Aug 13, 2016 | Garden
2001 Hyundai accent wouldn't start this morning after sitting two days prime and no codes kept screwing with it I primed and runs then only primes sometimes but still runs great miss chug
Hi Miss Chug:
I'd start by using some carb/injector cleaner and make sure that the fuel delivery system is working properly.
If this is a carb type engine, make sure the automatic choke is not sticking.
Jun 30, 2015 | Hyundai Cars & Trucks
I have a McC Power Mac 380. I have owned it since it was new and it doesn't have a lot of hours on it. I thought I emptied and used up the gas since it's last use, but now with fresh gas and new fuel...
did you clean the jets on the carb,take the jet out counting the complete turns prime it a few times, then put the jet back in with sth same amount of complete turns. then prime and start
Sep 12, 2010 | McCulloch Garden
When the car sits for a week the carb goes dry and is very hard to start.It also idles fine one day and the next day it idles rough and runs rich.
If you want to prevent the Carburetor from dry after sitting for a while I suggest letting the car run for 5-10 minutes . I do that with my 78 El Camino SS 350 and after the carb is primed it starts right up
Aug 29, 2010 | Edelbrock 18064 650 Cfm Avs Carburetor...
It will start for few seconds after i prime it, but it wont run.
Something is not allowing fuel to flow thru the carburetor. The usual suspect is water in the gasoline. Sometimes there can be some other debris causing the blockage. The needed repair is the same in both cases. The carb and fuel tank must be cleaned. If the mower is more than a year old, I also recommend replacing any rubber parts in the carb.
Aug 25, 2010 | Poulan "Poulan" Push Mower
I prime my tecumseh engine three times as stated. The lawn mower still will not start. How do I investigate to figure out what is wrong? I have taken it to a repair man twice. After I get it back it will...
This sounds like a fuel delivery problem. Maybe remove the carb and tear it down and then soak it overnight in a cleaner after removing all the moving parts...not real hard normally...then let dry and reassemble...If this doesn't improve the fuel delivery problem, maybe get another carb for it....Make sure the air filter is not plugged up, blocking air flow to the carb itself..just something to make sure of at first.
Jul 17, 2010 | Toro Lawn Mower With Toro Power Tools
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My 1990 40 hp evinrude carbs are leaking out both top n bottom
Sounds like it's time to replace the carbs and go boating
Aug 05, 2009 | Boating
Car sputters or dies when idling, but starts fine.
I suspect you have an idle circuit issue. When the thottle is closed, the throttle valve is almost closed (like 95%). The linkage on the throttle body is against the hard stop.
SO, when idling you need a way to let enough air into the engine to maintain an idle speed. The IAC, Idle Air Control valve is the way you do that and the engine computer controls the rate of air flow.
Sometimes it gets plugged up so you can clean it with a little carb cleaner. Might have to take it apart.
Also, you have a MAF, Mass Air Flow sensor that tells the computer how much air is flowing through the air cleaner intake at any time. The sensor gets coated with varnish and vies a false reading. Clean it gently with carb cleaner and a toothbrush.
Other than that, I would go to an auto parts store that can run a computer scan for free to see if you have any fault codes stored. They will tell you next stpes.
I assume you 2.0L SPI engine & not Zetec.
Idle Air Control (IAC) Valve —2.0L SPI Removal
  1. Disconnect the idle air control (IAC) valve electrical connector (air cleaner outlet tube removed for clarity).
  1. Remove the IAC valve.
  1. Remove and discard the IAC valve gasket.
cdecc8a.gif Mass Air Flow (MAF) Sensor Removal
  1. Remove the air cleaner outlet pipe.
  1. Disconnect the mass air flow (MAF) sensor electrical connector.
  1. Remove the MAF sensor.
clean element inside carefully
PS. A good running engine makes for a better running transmission
Mar 02, 2009 | 2003 Ford Focus
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
