Question about Ricoh Aficio 2035 Copier
I have a ricoh aficio 2045, the machine keeps displaying to turn the power switch of and on and call for service. whats causing this and how do i reset or repair this error.. Thanks
    Guru:
  • 642 Answers
It may seem that the unit is connected to a power outlet that is not suited to it, although for the life of me I cannot imagine anyone selling you a product not suited to your regions' power network. Try cold starting the machine.: Unplug from the outlet and leave it be for 30 seconds. Then get the power back on and see if the problem persists. As for the power supply, check on the back where the power cord goes into the machine. It should have a stamped area on the cover stating what voltage it should operate on. Make sure it corresponds to the grid voltage in your country. If you're not sure check here:
http://www.kropla.com/electric2.htm
If you had been using the unit before the above is of course irrelevant and you could reject this solution and request help again.
Posted on Aug 02, 2010
I have an sc 326 error code in my ricoh aficio 2045 copier
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
I am on way of frustration to solve this problem.when amachine swich on it displays service call message and flash at key button. the machine is ricoh 2045. gentle men please help me how to crack and...
look my friend goto yellow cancel and press 107 and hold on red cancel 3 times and go to ( copy sp ) and put 5801 and press excute and close machine and open it
Feb 07, 2011 | Ricoh Aficio 2035 Copier
I need to know the part number for the toner replacement bottle for the Ricoh Aficio 2045 PCL 6
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
Sep 09, 2010 | Office Equipment & Supplies
Aficio 2045 sc670
engine respond error
fault:
after powering on the machine,a respond was not recived from the engine within the specific time
possible causes:
bicu board
controller board
Sep 03, 2010 | Ricoh Aficio 450 Copier
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Jul 19, 2010 | Ricoh Aficio 2035 Copier
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
RIcoh Aficio 2045,turn off fax delivery report
download the manual from the www.ricoh-usa.com web site for the fax advanced features.
Refer to page50, from the pdf numbering.
Or at page147, from the document it self numbering.
Here is a link for quick find:http://www.ricoh-usa.com/downloads/manuals/bw/aficio2035/manuals/FaxAdvancedFeatures_PartII.pdf
Jan 21, 2010 | Office Equipment & Supplies
My ricoh aficio mp3010 keeps comming up with error sc 548 any body now wat to do. please help me
You need acces service progpam:
1. Press the clear modes key.
2. Enter 1-0-7.
3. Press the clear/stop key for more than 3 seconds untill the service program menu appears om the touch pamel display.
4. Enter in the service menu.
5. Turn OFF the power switch,unpluged cords,wait 10 sec,plugged cords then turn ON power switch.
Aug 02, 2009 | Ricoh Aficio 450 Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 2035 Copier Logo
172 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
