Question about Cameras
Hi I put new batteries in the camera and it comes up after a few minutes please replace batteries Thanks
    Scholar:
  • 104 Answers
I hope the camera is pulling the maximum out of ur batteries and so your batteries are getting drained soon. One better solution for your problem is to go for rechargeable batteries. They will reduce the cost on which u r spending for your batteries. You can charge it and use it when it is getting drained.
Posted on Aug 02, 2010
Camera continues to show" no battery" when I
Hi Shipley I get exactly the same with my *ist DL2 periodically. It doesn't happen every time but often enough to be irritating. Sometimes taking the batteries out and putting them back in a different order fixes it - sometimes it doesn't. Often If I put them in and then leave the camera for a few minutes before switching it on - that generally works. (but then again.......
I wish I knew the definitive answer.
Mar 25, 2011 | Pentax *ist DL Digital Camera
My Kodak Z650 camera just won't switch ON. I used the camera a few weeks ago and it was working fine and after using it, I removed the battery and packed it away for next use. The next time i tried using...
Hi there Make sure the new batteries are fully charged before used. After that remove the memory card & try to power on. If its not ON then i suggest you remove the battery & check the that place for any sulfur layer( green colored ) are there or not. Just clean that place & put the camera in sun light for 10 minutes. Because some time moisture make short the circuit board & that's why camera would not turn on. If its a moisture problem then after those operation it will start working. But if your camera power supply converter are damaged then its not possible to repair at home. So go for all these basic treatment & after that if you not success then i suggest you please visit Kodak service center for replacement or repair. Thanks.
Apr 02, 2010 | Kodak EasyShare Z650 Digital Camera
When I press the power button for my Olympus FE-190 to turn the camera on nothing happens. I haven't used it for a while so I initially thought that the battery might not have any charge. When I put the...
Most likely the battery has been depleted. When you are not using you camera you should always recharge the batteries every now and then. This ensures that they will last longer. Try buying a new battery for your camera.
Feb 28, 2010 | Olympus FE-190 Digital Camera
Empty batteries
Your camera may have been in wet conditions. So "short cut" may have been occurerd. Please firstly put your camera in a hot and dry room. Wait at least one day. After that process. Try again to use with brand new batteries. It will work I think.
Feb 22, 2010 | Olympus FE-210 Digital Camera
Reset Date and time
yes its possible. Please remove the internal battery once and then put it inside after few minutes. This will reset the date time. while you switch it on once again. it will prompt you to enter new date and time.
Regards
Sweet Rascal
Jan 28, 2010 | Fuji FinePix J10 Digital Camera
I do not know why my kodak c180 will not cut on. It is not the batteries because I have changed them several times. It is new. I just received a new memory card for it and when I wanted to put it in, the...
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 28, 2009 | Kodak EasyShare C180 Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Canon A400
Having using standard LR6 batteries in a Canon before you will only get 3 or 4 pics max before it drains the batteries. You really need high power AA's like 2300mAH+ rechargeables for any good performance or Lithium AA's
Aug 28, 2008 | Canon PowerShot A400 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
