Question about Extensis Suitcase X1
One side of the Presto Combination lock suitcase is locked and I can't open. The other side is open and won't close.
  • smiller173 Aug 02, 2010
    I have a attache case with Presto combination locks. The left lock is locked and can't be opened because I apparently forgot the combination. The rights latch is open and can't be closed for the same reason.
  • 857 Answers
Look through the gap between the number wheel and the frame of the briefcase.
Do one full rotation of the number wheel. While rotating, look for a dip line through the axial line of the number wheel. Keep the dial so that that line exactly faces you.
Now to find the correct number, add 5 to the number shown in front of the number wheel.
If the result crosses 9, you should subtract 5 from the number shown in front.
It should be done for each of the number wheels.
It should be done in a min :)
This results in the least number of combinations on each of the three wheels i.e 3* 10 = Only 30 combinations :)
Another Way- especially if you can't see the dip in the wheel- Set the combo to 0x0, (the middle number doesn't matter right now) and while holding the open lever as if to open the lock, spin the middle dial (that's the "x" in the notation I'm using)... If your combo is hit, the lock will spring open. If not, try 0x1, then 0x2, thru to 0x9, then 1x0,1x1,...1x9, then with 2, 3, etc. This allows only 100 options instead of 1000, and I just opened mine in about 4 minutes... (combo was 391, so even if it had been 999, it would have only taken about 12 minutes.
If this doesnot works counsult a repair guy.
Posted on Aug 02, 2010
    President:
  • 567 Answers
Hi there please explain the problem so i can find a solution soon as possible. Thank you
2 Suggested Answers
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
Hartmann suitcase. How do I open Presto lock with 3-digit combination?
Look for my tip on opening luggage with combination locks in this listing.
Nov 27, 2015 | Luggage & Travel
How to reset a combination lock for samsonite luggage?
if the suitcase is open, look for a little red tab on the inside. Move it to the other side of the little window, then change the combination. If the suitcase is locked, you will have to try from the outside to find the correct combination
Mar 11, 2015 | Samsonite Photography
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
By frequently resetting your lock combination, you decrease the chance that someone will break into your luggage.
If someone watches you open your luggage at baggage claim while going through security or at a hotel, they may break into your luggage when they encounter you on another leg of your journey.
Change your lock after every major flight or trip to help keep your items safe.
Avoid easy to guess passwords, as well, such as sequential numbers, all the same number or birthdays.
Open your lock by inputting the current combination.
New Prestolocks have a factory set combination of "0-0-0."
Turn the shackle 180 degrees.
Press the shackle down and turn it 90 degrees to the left or right.
Input the new combination.
Move the shackle 90 degrees so that it is 180 degrees from its locked position.
Take your hand off the shackle and pull it out.
Turn it back to the locked position.
Push the shackle into the lock and turn at least one of the lock's dials.
Write down your new combination.
Keep this paper in a safe place for future reference.
Jun 20, 2013 | Extensis Suitcase X1
My combination on my california pak luggage does not work. How can I open/reset the combination?
If the lock is unlocked - try this: Unzip the inside liner, find the lock backing plate. Undo the 2 screws and remove the lock from the suitcase. Find a good strong light, and maybe a magnifying glass. Look at the 3 holes in the back and rotate the dials until the 3 slots are lined up. Open and close the lock, noting the combination. Re-assemble the lock on the suitcase. Hold the lock open, dial in your own combination. Make sure it works before locking it up. Cheers
Aug 27, 2011 | Locks & Locksmithing
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
I don't remember the combination but it is open. please tell me how to set it
same problem with the spinner model.
My suitcase is open but since I dont have the lock combination (3 digits) I can't close it (not lock it, just close the case) . The combination changed when the case was open - is there a way to reset it ?
Mar 05, 2010 | Samsonite Tripod
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Apr 11, 2009 | Samsonite Tripod
Presto combination lock on a suitcase will not open
Jan 14, 2009 | Extensis Suitcase X1
Extensis Suitcase X1 Logo
239 people viewed this question
Top Extensis Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Extensis Computer and Internet Expert? Answer questions, earn points and help others
