Question about Zanussi WJD1257S Front Load Washer
Will not sin or drain
E20 come up the drain pipe is blocked what can i do
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Take out and clean the filt located behind the flap bottom right at the front. if this does not help the blockage will be in the drain pump or the pump faulty.
Posted on Aug 02, 2010
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
Have an error code on my machine E20 - is it terminal?
You need to clear out the drain pump. E20 means drain blocked. You should be able to access the pump from the front bottom by unscrewing and removing the filter. If not then you will need to tilt the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. If it is clear then try removing the pipe that goes from the pump to the base of the tub. Commonly a sock gets stuck. Hope this helps
Mar 04, 2011 | AEG Lavamat 72640 Front Load Washer
E20 error code on gltf2940
The problem is with the pump, or drain hoses.
This caused because there are some things like coins dust blocking the water path.Clean the pump and drain pipe ,this will solve the problem
Thank You
Sep 13, 2010 | Frigidaire GLTF2940E Front Load Washer
My drum holds water and blinks the code e20
This caused because there are some things like coins dust blocking the water path.Clean the pump and the pipe this will solve the problem
Thank You
Sep 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code e20
E20 means you have a drain problem. Check the drain filter on your machine to make sure it isn't blocked by fluff/coins/etc. Should work again unless you have a bust pump (which I had).
If machine is full of water, do an emergency drain through the little pipe on the bottom front. Good luck.
Jan 18, 2010 | AEG Lavamat 72640 Front Load Washer
E20 what does that mean?
E20 is a drain problem. Clean out the drain filter, normally found bottom of machine. Do emergency drain first or you will flood the room if there is water sitting in drum. Hopefully you just have a blocked filter or pipe, otherwise you may have to replace pump if it has failed.
Why can i not get the dryer to work? error E20 is flashing.
HI,
Can you hear the pump trying to drain it when you start a cycle? If not it needs a new pump.
Is there a block in the drainage pipe (blow down it and see if it bubbles in the filter compartment). Or a block in the drain - try pouring some water down in.
Otherwise, I had the same problem (an E20 but a clean filter, no blockage and working pump) and it turned out the condenser (a large plastic vessel) or the right side of the machie (you have to take the whole back off) was full of fluff. The engineer just used a wire hanger and ran it under water to clean it out.
If you've found that it hasn't been drying the clothes fully recently that could well be the problem.
Sep 24, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
Displaying error 20
Most likely is is blocked, so a good clean out is needed.
(turn off water and unplug) Pull out the machine, take outlet hose out, and clear drainpipe with a drain cleaner - then rinse through.
Clean outside of pipe, and check inside condition.
Replace & reconnect.
Try 2 cups of washing soda in the machine and do 2 hot washes to try and flush blocks through.
If this does not improve matters, you may have to strip the machine to clear the pump and outlet pipe manually.
Aug 20, 2009 | Frigidaire Affinity ATF6000F Front Load...
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi WJD1257S Front Load Washer Logo
43 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
