Likely problems when working in woodworkshop - Computers & Internet
    President:
  • 1,768 Answers
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away from any cordless phone or TV sets and try to log on to the internet.
This is for all routers to set up wirelessly.
Posted on Aug 02, 2010
Anyone know what oops the system encountered a problem (#007) in gmail means?
I encountered that problem. It was ongoing for quite a while. Tried clearing cache. Didn't work. Tried restarting after clearing cache. Didn't work. Tried using different browsers. Didn't work. Tried using different computers. Didn't work, Tried using different computers at different locations. Didn't work. Tried HTML Didn't work.
Closed out my gmail accounts, went to yahoo. Problem solved. Gawrsh, I had more problems with gmail, within months of use, than I did with well over twenty-five years of Hotmail.
May 01, 2014 | Computers & Internet
What's your problem?my laptop is aspire 5542 ,i got problem with my keyboard it's some keys work and some does not work this time i am using onscreen keyboard please help me,yesterday it work
From your description the main keypad will need to be replaced, there are no seviceable parts, I suggest a computer tech to remedy the problem.
Mar 03, 2012 | Acer Aspire Computers & Internet
When you want to fix network problem because my network said not found what is the problem of it
Try powering down everything. Then start with your modem, then your router, then your computer.
If problem persists, try plugging your computer directly to the modem. See if it works. If not, problem is with your modem and you should contact your carrier.
If it's working, try plugging the computer to the router. If it's working then the router is working and your wireless is your next target.
Try navigating with your phone. If your phone works, problem with your computer's wifi.
Sep 09, 2011 | Electric Measuring Tools & Sensors
Acer Aspire 5532 Keyboard works in BIOS, but stops working once Windows 7 loads. Same with the touchpad, once Windows 7 loads it stops working. However I can plug in a usb mouse and that will work.
look there is a problem with the touchbad diver and this is common but the keyboard must work it s nothing with the keyboard so please check if all the key board works under another operating system and then if it wrks try to reinstall windows 7 again and it must work conntact me if you still have a keyboard problem you must try to plug a usp keyboard and see if it work so you have a problem with your board again if it worked you have a problem with your keyboard if it didn't work then try install windows 7 agin
Nov 03, 2009 | Computers & Internet
Identical problem 04 chev dvd works and radio works
I don't think that it is any kind of problem when dvd and radion works. alternatively you can switch 'em off....
Jul 05, 2009 | 2004 Chevrolet Silverado 2500HD
Hp officejet j4580 print cartridge problem (tri-color)
I discovered on mine, exact same problem, I opened the tray, removed the cartridge, and forced it back in hard and fast. It didn't work the first 12 times but after that, it got a solid connection and it worked. Works fine now. Anyway that's the problem and the problem isn't the cartridge (genuine hp cart here). The problem is on the printer side, the pins that hit the cartridge. Anyway get rough with it, slam it in and out, close the tray, if it doesn't work within 5 seconds, open the tray and do it again. It WILL work.
Jun 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
Problem in scanned images uploading
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers.
Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors.
If you had trace to that problem, then replace the whole unit of hub connectors.
Aug 08, 2008 | Microsoft Windows XP Professional With...
Headset problem with Uniden 1558
Determine if this is a VOX problem or a headset problem.
Turn off the VOX. Does the headset work for normal transmit and receive?
Remove the headsets. Do the radios work normally on speaker?
Plug one headset in And test with the (other) radio in speaker mode. Does it work? Now turn on VOX in this mode (yes it will work this way). Does vox work (put you mouth right on the mic)
If so swap headsets and try the other.
If one Hset works but not the other its the headset. If neither works its likely the radio ..but before you decide try the same headset experiment on the other radio. Find out which of the 4 devices the problem follows.
Happy New year
Dec 24, 2007 | Uniden GMR-1558 / 2CK 2-Way Radio
Computers & Internet Logo
Alun Cox
David Payne
David Payne
