Question about Maytag MSD2656G Side by Side Refrigerator
Refrigerator Defrost Troubleshooting
Maytag side-by-side refrigerator Model:MSD2556.
Question: What is the procedure for manually making the refrigerator go into the defrost mode. It has the solid state module ("adaptive Frost Control") that controls the defrost (not the older defrost timer).
  • Mike883 Sep 08, 2008
    Where is the adaptive defrost control located? (Model MSD2957AEW)
    Genius:
  • 1,073 Answers
You cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Posted on Apr 25, 2008
Drip pan overflowing with water on whirlpool side by side refrigerator.
Posted on May 22, 2008
Defrost board
I am not sure about the question you are asking but yes the model MSD2556 Click here=> MSD2556AES Controls location 13 in that photo is your=> 61005988 Defrost Control Board
A parts list with this part can be found on page 2 and 3 of the MSD2556AES Parts Manual PDF for other manuals click HEREIf you have questions please let me know, Thanks Sea Breeze
Nov 20, 2012 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Ice is bulding up in the freezer side
Its a defrost problem.Click this link below and follow the troubleshooting procedure, before replacing any part:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- this should help.thanks.Helpmech.
Jun 19, 2011 | Maytag MZD2665HE Side by Side Refrigerator
Hello, the refrigerator side is not cooling, but the freezer is working perfectly. Our fridge is 26 cu instead of 25.6
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
No cooling in the refrigerator or freezer, coils are clear. fan seems to be working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 29, 2010 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
ICE MAKER NOT WORKING HELP
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hfhj
Sep 28, 2010 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Fridge is not staying cool after defrost--only stays cool for a couple of days then stops cooling until we defrost again
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 28, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Trouble shooting defrost system
you can not manually start a defrost cycle
go to the freezer and check the heater and bimetal they are in the evaperator coil if these parts check good then replace the adaptive defrost control
Apr 25, 2008 | Maytag MSD2656G Side by Side Refrigerator
Maytag 25 cu side by side
Sounds like your defrost system isn't working. There is a timer that turns off the compressor and fans then turns on the heater under the coils to defrost them. The defrost bi-metal thermostat could be "open" and not letting power to the heat element, the heat element itself could be bad or the defrost timer could be bad, that's about it for the defrost cycle system. I see this quite a bit and it's "usually" the adaptive defrost timer. Under the fridge kickpanel in the front is some paperwork and troubleshooting sheets. I think this model you push the light switch in 5 times in 10 seconds to force a defrost cycle for testing. With the unit running (compressor, evap fan, condensor fan all running) in a normal cooling cycle open the fresh food door and press the light switch in 5 times within 10 seconds. If all the compressor and fans turn off right away then the adaptive defrost board is OK and it's the heat element or bi-metal. I'll bet it's the adaptive defrost board though... here's a diagram of where it is and where to get one. It's REAL easy to get to and change out (then test as above). http://www.partselect.com/Schematics/Maytag/A50-6.gif
Feb 12, 2007 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Maytag MSD2656G Side by Side Refrigerator Logo
595 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
